legal or not?
Old Jul 21, 2005 | 07:06 AM
codemaster63's Avatar
Default legal or not?
I was considering buying a Megan header, but I'm not sure if it's street legal or not since the auction doesn't say racing header or not. Can someone clarify to me if this header will be street legal.
http://cgi.ebay.com/ebaymotors...73937
Old Jul 21, 2005 | 07:13 AM
P_Adams's Avatar
Default Re: legal or not? (codemaster63)
As long as the header you're considering duplicates the original exhaust manifold for mounting an o2 sensor (if it had one), you'll be alright. If it doesn't, you'll have to make provisions for mounting it. Most emission laws are written whereas all original emissions components must be present and operating correctly. What they're mounted to makes no difference (IE: cast manifold / header)
P
Old Jul 21, 2005 | 07:16 AM
blkknight619's Avatar
depends where you live in california your not allowed to use any type of racing headers...the only headers that you allowed to install in california is sports headers which really bites you in the ***
Old Jul 21, 2005 | 07:44 AM
P_Adams's Avatar
Generally, what 'blkknight619' confirms is that "sport" (street) headers have the o2 provision, while the "racing" (competition) headers do not. The sport header may not handycap you as much as you think. I've caught some posts on other (gasp) forums where many have had to rework the collectors on proported "racing headers" because of poor flow/design.
Most motorheads from the left coast will confirm the C.A.R.B. (California Air Resourses Board) has forever been a pain in the "patootie", but unfortunately it's the only game in town for street machines.
P
Old Jul 21, 2005 | 07:59 AM
Default Re: legal or not? (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkknight619 &raquo;</TD></TR><TR><TD CLASS="quote">depends where you live in california your not allowed to use any type of racing headers...the only headers that you allowed to install in california is sports headers which really bites you in the *** </TD></TR></TABLE>
Well I live in Texas and they are not the most environmentally concerned state in the U.S., but I believe I did see a bung for an 02 sensor on the header, although it looks like it could be welded up.
Old Jul 21, 2005 | 09:22 AM
SpeedFreak77's Avatar
You should be ok, California is the state where this would most likely be an issue but as long as you can hook up your O2 sensor you should be fine since the emissions won't be affected that much.
Old Jul 21, 2005 | 05:15 PM
drifter_for_life06's Avatar
i have on
its perfectly fine
in PA at least
Old Jul 21, 2005 | 07:21 PM
fw190bvi's Avatar
Default Re: legal or not? (blkknight619)
wtf is the difference between a "racing" and a "sports" header, in terms of emissions. your a tool
Old Jul 21, 2005 | 09:06 PM
ImmaSquashYou's Avatar
i believe that as long as you still have teh cat, n emissions is fine, everything is legal.
Old Jul 22, 2005 | 01:53 PM
pyrojeff's Avatar
Default Re: (ImmaSquashYou)
As long as it does not modify the position of the catalytic converter or the oxygen sensor(s), it should be perfectly legal.
Although in California, its a whole different situation.
Old Jul 22, 2005 | 05:03 PM
eavtimmy's Avatar
On the header pipes you buy there is usually a small metal plate welded to the header that will say the brand name, and usually has an "EO number" beneath that. I would expect any brand name header to have the EO number, which is just a carb exemption number. If the inspectors think its a problem they will look and see the EO number and you will be set. Of course, you could always just put the OEM heat shield back over them on inspection day.
pdapaul
May 4, 2016 08:40 PM
tomii.dc-5
Oct 2, 2008 05:54 PM
slowpokecivic
10
Nov 23, 2006 02:20 AM
976
Aug 20, 2004 10:26 AM
FreeMyndz v.FP
Jan 23, 2002 07:43 AM
