clank clank sound
Old Jul 21, 2005 | 05:09 AM
BK101's Avatar
Default clank clank sound
hi all,
i am getting a clank clank when turning the steering wheel right to left pass center
when i press on the brake. its doesn't happen when i am not on the brake.
anyone experience this ? its a 98 accord ex sedan.
thanks
Old Jul 21, 2005 | 05:15 AM
nyjts2856's Avatar
Default Re: clank clank sound (BK101)
In my experience with that noise that problem should be the CV Axle is bad. Have the CV Axle replaced. The boot broke and you lost all the grease so thats why it is clicking now. Hope this helps.
Will
Old Jul 21, 2005 | 05:18 AM
deserthonda's Avatar
have you taken the time to remove the wheels and chk things out?? ..like ny stated it could be cv joint but then it should be noisy on turns when you are not applying brakes as well .. ..just go and inspect things
Old Jul 21, 2005 | 05:30 AM
BK101's Avatar
Default Re: clank clank sound (deserthonda)
its not the clicking u hear from a bad cv joint. i can hear the noise even when i am
in park position and turning the wheel with the brake pressed.
i looked at the cv joints, the boots are fine.
Old Jul 21, 2005 | 07:22 AM
blkknight619's Avatar
it could be your steering colum
Old Jul 22, 2005 | 06:10 AM
BK101's Avatar
Default Re: clank clank sound (blkknight619)
after going to a shop this morning,
they said it is the wheel bearings, both sides ...
should i change the hub at the same time. ?
i believe the hub is a dealer item
Old Jul 22, 2005 | 06:17 AM
the wheel bearing???? mmmmmmm you hear noise from turning wheel standing still and they say it is wheel bearings ..i would have a second opinion that does not sound right to me ......is this a honda place or joe blow down the street ??
Old Jul 22, 2005 | 06:56 AM
BK101's Avatar
its a local joe blow..
he put the car on the lift.. and show me the play on the wheels..
12:00 and 6:00 o' clock their was movement ...
and 9:00 - 3:00 o'clock movement too.
Old Jul 22, 2005 | 11:22 AM
make sure lugs nuts were tight and axle nut as well ???ball joints ok??
Solstic
Oct 6, 2013 11:06 PM
SHystrdyGSRtdy
Mar 4, 2013 01:24 PM
dlewis2583
Feb 24, 2013 09:32 AM
yaced
15
Apr 5, 2006 10:02 AM
spencedogg
22
Jun 4, 2003 09:15 PM
