Amber lit clock
Old Jul 21, 2005 | 04:32 AM
D Grade's Avatar
Default Amber lit clock
JDM, aftermarket, or.....? I'm in the process of doing a custom all amber lit dash, so I need a clock to match. Does someone perhaps know the trick to changing the back light to a dark amber color?
Old Jul 21, 2005 | 05:00 AM
spiceisler's Avatar
Default Re: Amber lit clock (Dieselboys MK3)
Use led's with a 10k resistor.
Old Jul 23, 2005 | 05:02 AM
D Grade's Avatar
Default Re: Amber lit clock (clean90Si)
Where abouts are the best places to find these LED's? What is involved as far as install?
Old Jul 25, 2005 | 05:39 AM
spiceisler's Avatar
You'll have to replace the stock illumination lights in the cluster. You'll also have to be creative with the mounting.
http://www.radlites.com/
http://www.signaldynamics.com/
http://www.customdynamics.com/...s.htm
http://www.superbrightleds.com/led_prods.htm
Old Jul 25, 2005 | 09:34 AM
SOHCwarrior's Avatar
https://honda-tech.com/zerothread?id=721388
I did this on mine and it looks great. and dont forget to cut the black and red wire to keep it bright all the time
Old Jul 27, 2005 | 02:50 PM
D Grade's Avatar
Default Re: Amber lit clock (SOHCwarrior)
Thanks alot. What I ended up doing was cutting a clear piece piece of plastic off of a package I had to fit the face of the clock on the inside. I then used some of the same amber transparent hobby paint I used on my gauge cluster bulbs and it came out great.
jose_germanDC4
Dec 21, 2010 09:07 PM
eg93LS
24
Aug 21, 2009 12:52 PM
cyang08
21
Jan 17, 2007 05:57 PM
dogbiscuit
Oct 25, 2005 04:45 PM
jdblack1
27
Sep 4, 2002 12:18 PM
