how do you make your dash glow red?
i would like to make my dash and instrament lights look like these.
http://i11.ebayimg.com/06/i/000/7e/3b/0d67_12.JPG
http://i23.ebayimg.com/02/i/000/7e/3b/04fe_12.JPG
does anyone have the picture to how the bulbs in each of these look so i can buy the right ones for them??
Re: how do you make your dash glow red? (cyang08)
i did mine with blue LEDs and i assume you could do the same with red LEDs
http://www.clubcivic.com/board...t=LED
that link explains how i did it.. the hard part is getting a nice easy color but if you take yoru time it will come out good..
cute little bastard
cute little bastard
Re: how do you make your dash glow red? (mikey-ej7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey-ej7 »</TD></TR><TR><TD CLASS="quote">looks like a lot of work </TD></TR></TABLE>
Doing the cluster is easy as hell. The climate control is possibly one of the most difficult things to do.
Re: how do you make your dash glow red? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">
Doing the cluster is easy as hell. The climate control is possibly one of the most difficult things to do.</TD></TR></TABLE>
Yes.
I bent the cable for the temperature control when I did mine, I have yet to straighten it out.
Though as it sits now because of the bend in the cable about 1-2cm from the right is "full" hot - obviously it can't pull all the way out for "full" cold. .
It'll straighten I think with a pair of needle-nose pliars, but I haven't gotten around to it yet.
@ OP:
It really isn't, there's 3 screws that hold the bezel on, then 4 (in a rectangle pattern) that hold the cluster in.
Then the cluster just unplugs, the bulbs are on the back of the cluster.
The temp control is the only tricky part. You can figure it out once you have it out, but getting it out can be a bit tricky - only because the one plug dead-center on the top is a bitch to get to. Only thing I could recommend is what I did which was use a micro-screw driver to push the pin down while I used a kelly clamp to pull the plug out.
PS:
Not trying to thread jack.
Anybody have any tips for straightening the temperature adjuster cable?
I figure i can do it with a pair of needle-nose, but I still can't get the right angle on it .
Any suggestions there? I had to bend it to remove it, that's why it's bent . Doesn't allow my temp to go all the way over to the coldest b/c it's about 1-2cm offset of the hot side.
Yes.
@ OP:
PS:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">This
http://cgi.ebay.com/Red-Light-...wItem
+ this:
https://honda-tech.com/zerothread?id=661308
i tried the bulb covers and they were ok.. but the LED light is way more clean imo... it IS more of a hassle.. but i prefer the results i recieved with them..
+ this:
Re: how do you make your dash glow red? (oc_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oc_civic »</TD></TR><TR><TD CLASS="quote">
i tried the bulb covers and they were ok.. but the LED light is way more clean imo... it IS more of a hassle.. but i prefer the results i recieved with them..</TD></TR></TABLE>
Just buy the red bulbs from autolumination.com for like 10 bucks for the whole set...that's what I did, worked perfectly.
http://autolumination.com/74.htm
They're $.99 a piece and you need I believe 2 #74's, and 5 #24's (which are also $.99 a piece).
It's not an expensive project.
Just scroll down, the regular old bulbs.
Such as:
#24's
#74's
You don't need the twist lock bases, get the wedge ones (ones in the pic).
PS:
My friend did the same to his tercel - 'cept with green (teal exterior). My other friend put blue's in his g/f's EJ8 b/c she liked the way the VW dashes lit up.
It's up to you. I never stuck around to see how the blue's turned out but we took a ride down to NJ during the day, slept at her mom's house, and the car was gone the next day ( to NJ) - so I never got to see how the blue bulbs looked .
Such as:
#24's
#74's
PS:
Re: how do you make your dash glow red? (Syndacate)
It is amazing how this thread did not get the:
"This should be in the A/C forum not here. This is a technical forum."
Yet someone posting an introduction to themselves get a little heat for so doing so.
m-
m-
cute little bastard
Re: how do you make your dash glow red? (Mario_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D »</TD></TR><TR><TD CLASS="quote">It is amazing how this thread did not get the:
m-</TD></TR></TABLE>
Maybe because theres at least a question here where the other one is completely pointless.
Oh but of course. An A/C question in the "techinical forum" is justified by have a question.
m-
m-
just taking a look in here...i read the title and said "WOoOW!"
lol...i thought someone was trying to make the DASHboard glow red....but then noticed it was the cluster and climate control...
uhm..you might also want to get the JDM clock too...
Maybe because theres at least a question here where the other one is completely pointless. </TD></TR></TABLE>
I have to agree.
This should have been a 1 or 2 post answer thread and that should have been it, then it shoulda went away. Just didn't happen like that this time. I mean putting amber bulbs in isn't exactly an act of congress.
I have to agree.
Re: how do you make your dash glow red? (B18CivicEg)
its amazing anyone browses this site.. SURE you can get answers.. and SURE there are people here who know a LOT of good ****.. but i mean every time you post a question its like a race to see who can talk the most ****..
what's worse posting a legitimate question in the wrong forum.. or the next seventeen posts bitching about it... maybe it would be helpful if people could get over themselves a little bit..
oc_civic
question i did not see this touched on in your write up so ill ask.
when you put in the leds did it effect the ability for you to use the dimmer switch to tone the light down or up??
Re: how do you make your dash glow red? (oddball49)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddball49 »</TD></TR><TR><TD CLASS="quote">oc_civic
when you put in the leds did it effect the ability for you to use the dimmer switch to tone the light down or up?? </TD></TR></TABLE>
nope it works fine
i left the two top lights stock (the ones that illuminate the needles) so that they stayed nice and white.. it created a good contrast between the blue gauges and the white needles..
but yeah dimmer works fine..
nope it works fine
Risky Business
It's really not...
It's really not...
Looks good, ive been wanting to do this for awhile. Looked for kits and such but couldnt find the ones for my cluster, but since all u do is change and wire da bulbs, looks pretty easy. thanks for da links and tips.
