uh oh...CEL
Old Jul 20, 2005 | 11:53 PM
black cx's Avatar
Default uh oh...CEL
have a eg with a jdm type r motor. I threw a cel tonight while driving normal on the freeway like 65-70 mph. All of a sudden a CEL comes on and i drive off to 7-11 to buy a paper clip. I checked it and i think i am throwing a CEL 1.....so i dont know whats up..I swapped in a Toda Header and a Toda Program ecu the day before. Is it the ecu or header? I never threw a cel with the stock JDM ITR ecu. Also, i turned back on my car, the cel is gone. I gun it...and it doesnt pull as hard and idont think i have vtec.
1 O2A - Oxygen sensor #1
what does that mean?
Old Jul 20, 2005 | 11:56 PM
Kyles ej1's Avatar
Default Re: uh oh...CEL (black cx)
im guessing its the ecu not reading that your o2 sensor is in or something. it is in right?
Old Jul 21, 2005 | 12:00 AM
black cx's Avatar
Default Re: uh oh...CEL (93ejay1)
the o2 sensor is in the 02 bung
Old Jul 21, 2005 | 12:01 AM
_Cyclone_'s Avatar
Swap back in the ITR ecu to see if it behaves the same way. Stupid question, but you remembered to plug it back in, right?
Old Jul 21, 2005 | 12:02 AM
black cx's Avatar
Default Re: uh oh...CEL (_Cyclone_)
yes, its plugged back in. What does that 02 CEL mean? Like what about the 02 sensor?
Old Jul 21, 2005 | 12:04 AM
Kyles ej1's Avatar
its reading that its bad
Old Jul 21, 2005 | 12:37 AM
_Cyclone_'s Avatar
OBD 1 can be kind of vague. That code could basically mean the O2 isn't sending any signal... it's reading too lean or too rich, not switching properly or fast enough, or the heater may have failed. Actually, I don't know if there's a seperate code in the OBD 1 system for O2 heaters or not.
Old Jul 21, 2005 | 09:46 AM
black cx's Avatar
is it safe to drive around with that cel?
Old Jul 21, 2005 | 10:16 AM
Kyles ej1's Avatar
yes but it will prob run like **** and u will get crappy gas mileage
Old Jul 21, 2005 | 10:43 AM
black cx's Avatar
but, when i turn back on the car, the cel is not there??? only if i plug in the pin...
Old Jul 21, 2005 | 11:34 AM
Kyles ej1's Avatar
yea that means your still throwing a cel. if there werent any then nothing would happen when u try to check it
Old Jul 21, 2005 | 11:36 AM
black cx's Avatar
thanks, imma just go to the shop that did my swap and see whats up.
s13hero
Nov 13, 2011 05:16 PM
4dek
Aug 6, 2008 04:48 AM
ef8gsrcrx
Jun 9, 2008 12:02 AM
LostAndFound
Aug 29, 2006 07:19 AM
black cx
Jul 21, 2005 09:44 AM
