will this work??? po8 auto ecu chipped so now it can be use on a 5 speed tranny?
okay, i just want know. if u have an auto p08 ecu and then u chip it, would the program change everything so it can be use on a 5speed tranny?
The ecu would have to be modified to not look for an auto tranny.
(Auto to manual ecu conversion)
would a chip do that? or if u just chip it, will it still be an auto ecu? lets just said it chipped mugen spec
Im not to familiar with moding ecus. but from my understanding an auto can be converted to manual by either chipping it or changing a few jumpers, in general.
Im guessing ur asking about the one u want to buy from me. Personally i dont know if its just the chip that convered it or if the jumpers were changed as well. Its not to hard to change the jumpers though as long as u can sodder.
The only problem u'd get from running an auto ecu on a manual car is a CEL because the ecu will look for some sensor auto tranny have. & this ecu did not throw a CEL when put on my car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">u just need to change a few jumpers and your set</TD></TR></TABLE>
ditto, and the info is on here, just search for which ones to remove and which to jump
converting from auto to manual involves removing two resitors and replacing one with a jumper wire. im not sure about the P08 ecus, but thats the case with P06,P28,etc
brad22486
Jan 25, 2012 09:46 AM
