b16a ecu mapping
hi,
I bought a car that swap civic engine to b16a sohc, i am not sure is 16a1, a2 etc...but now i want to fix VAFC but i dont have the ECU mapping.....anyone can help, or any site to download the ecu mapping? thanks!
Modified by evoX2 at 7:29 PM 7/21/2005
most b series are dohc, you may want to check your block for the "d" designation to the left of the exhaust manifold. If you're vtec is acting up throw in a jumper wire to the test terminals to find out if its the pressure switch or the solenoid. 21 (two long flashes from the check engine light and one short one) should be teh solenoid and 22 the switch (not sure completely check a service manual) as well the mapping for the wires is in the back of book.
kungking5
Dec 12, 2006 09:47 PM
brian2903
Dec 11, 2003 07:20 PM
