NEED HELP--cel np codes won't rev past 3500 rpm
Old Jul 20, 2005 | 09:14 PM
93si-hybrid's Avatar
Default NEED HELP--cel np codes won't rev past 3500 rpm
Hi i have a 93 si hatch with a 94 gsr swap. I have a cel when the car is running,when i jump the wire there is no cel. Also it won't rev past 3500 rpm. I'm using a p72.
I just wired up the iab, and just put in my o2. I had it running fine with the knock sensor wired and no iab or o2 in. Any help would be great. Thanks.
Old Jul 21, 2005 | 07:56 AM
Anybody else have this prolem?
Old Jul 21, 2005 | 12:43 PM
mtber's Avatar
Default Re: (93si-hybrid)
When you jump the service connector.. the cel stays solid ?
If so, your ecu is probably bad or you have a major issue somewhere.
Old Jul 21, 2005 | 01:11 PM
when i start the car it comes on. i shut it off then jump it and there is no cel.
Modified by 93si-hybrid at 4:32 PM 7/21/2005
Old Jul 22, 2005 | 04:52 AM
I fixed the 3500 rev limit problem. now just the cel.
Old Jul 23, 2005 | 03:10 PM
3gteg96's Avatar
Default Re: NEED HELP--cel np codes won't rev past 3500 rpm (93si-hybrid)
Dude HELP!...How did u fix your rev problem.I was told mine was my distb.But i wanna make sure someone has hard wired mine in..I checked all the wires from ecu to distb all match up..How did u fix urs?....
N/A aka:poor
Jun 19, 2014 02:03 PM
slammedz6ef
Jun 11, 2011 05:56 PM
j0keefe21
Engine Management and Tuning
Mar 22, 2010 08:01 PM
protocol06
Oct 7, 2003 12:56 PM
