[REQ-DIY] How to install a NRG quick release/Bride Steering wheel/Hub
Title says it... i've tried searching... google isnt helping and the only DIY i saw was how to take the steering wheel off.
I have a 1992 LX sedan.
Please help.
as a bonus..
Please help.
as a bonus..
http://www.hondaswap.com/forum...35291
https://honda-tech.com/zerothread?id=437448
The quick release is pretty straight forward. Once you get the hub installed just wire up the wires and mount it in between the steering wheel and hub.
ok quick question... i just installed my steering wheel and hub... and my horn doesnt work.. we had to cut my clock spring and the SRS light is staying lit... what did i do wrong???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">When you disconnected the old steering wheel, did you cut the tape thing that's for the SRS? The horn is controlled by that. </TD></TR></TABLE>
uhh.. yea we cut that... was I not supposed to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxBurnoutKing »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>I did the same thing cause I got frustrated. That tape thing is actually wiring for the SRS which also controls the horn. Your srs system is fucked now and won't work, neither will your horn.
What I did was wire up my horn to a push button so I could pass inspection.
just buy a new column srs harness if you want the horn to work, Im sure you can find a way to relocate the wires alone to work. Your srs system isn't going to work reguardless, so why not crack open the reel and figure out how to wire the horn so that it will still work?
Hope that helps..
Ohh, and for you people saying to search, please read the rules.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by `92-00 Civic / Del Sol Rules and Guidelines »</TD></TR><TR><TD CLASS="quote">3.C. Posting in a thread "search noob" or anything of that nature now automatically warrants a % drop. This is a violation of the TOS, as it is post whoring, and frankly we're sick of it. If you can't provide a link to a thread, or any useful information, then don't bother posting at all.</TD></TR></TABLE>
Hope that helps..
my horn works... u just need to take the wire from the harness and get it to touch the metal ring on the back of the hub.. then that wire on the hub plugs into the one on the QR and then make one metal prong on the horn button only touch the horn mechanism on the NRG part and the other ground out to the QR
vroomeo
Feb 20, 2010 08:12 PM
