Car died and now it won't start...
Old Jul 20, 2005 | 03:41 PM
CornFlake340's Avatar
Default Car died and now it won't start...
I was driving home the other day and my car died. I thought it was a fuel problem but the fuel pump is turning on and such. The car will turnover but it won't start. How do I check to see if its getting fire? Or what the possible problem may be?
Old Jul 20, 2005 | 03:55 PM
transpar_nt's Avatar
Default Re: Car died and now it won't start... (CornFlake340)
To check if you're getting a spark, pull one of the plug wires and have a friend crank the engine. Slowly move the end closer and closer to the plug and you should see a spark. This means it works. It most likely isn't the problem though. Maybe pull the plugs and see if they have oil on them. Eventually when gaskets and o-rings get old they'll leak and drench the plugs with oil.
What kind of car do you have and what is the service history like? Mileage? It could be any number of things so without more info anything anyone says would just be a guess. Have you checked for any CEL's? If you don't know how, go here: http://www.hstuners.com/forums...23007
Chances are you'll have one or more of those popping up. Check those first and you'll know where to start
Old Jul 20, 2005 | 06:02 PM
93Civac's Avatar
If its not getting spark then your coil may have gone bad also.
Old Jul 20, 2005 | 08:07 PM
So... if umm, the CEL stays on after I short the pins... what does that mean?
Old Jul 20, 2005 | 08:13 PM
clm's Avatar
clm
Default Re: (93Civac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac &raquo;</TD></TR><TR><TD CLASS="quote">If its not getting spark then your coil may have gone bad also.</TD></TR></TABLE>
Or the igniter. Common problem on Hondas.
Old Jul 20, 2005 | 08:37 PM
Default Re: (clm)
What would also cause the car to quit running, after it has already been started and driving for a bit?
Old Jul 20, 2005 | 08:48 PM
red-eg6's Avatar
Default Re: (CornFlake340)
clogged injectors! lol when i put a new motor in mine it ran the stoped. the injectors were clogged and i dont kno how they got clogged. but when i pulled the fuel line off the fuel rail it spritced everywhere so thats a start. and check ur sensors to see there connected and spark and so on. if all else fails check compression.
about:blank
12
Jan 19, 2008 02:13 AM
Fatty_1775
Jun 12, 2007 10:40 PM
cb7joba
Jan 1, 2007 11:11 AM
ICeDoUt
Aug 18, 2005 01:38 PM
valerie34
Jun 30, 2005 07:42 AM
