shift linkage removal
Old Jul 20, 2005 | 02:46 PM
TEG777's Avatar
Default shift linkage removal
iam removing the shift linkage from the tranny, its a 97 integra LS, there is a little pin holding it, tried to knock it out, that didnt work it wont move, anyone know how to take it off
Old Jul 20, 2005 | 02:47 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: shift linkage removal (boostinteg777)
They don't call it a bitch pin for no reason. You just have to wack at it until it comes out. I believe you can use an 8mm punch.
I used the extension of a 1/4 ratchet. Worked nicely.
Old Jul 20, 2005 | 02:52 PM
TEG777's Avatar
Default Re: shift linkage removal (shamoo)
ive tried wacking, still wont go
Old Jul 20, 2005 | 03:40 PM
mattssi's Avatar
the way i do it is with a impact hammer and a air compressor. Other than that, be prepared to have sore forearms until you can get the car jacked up high enough to get a real swing at it. you need to give yourself enough space.
Old Jul 20, 2005 | 04:58 PM
freakasis's Avatar
either use a hammer and an extension like he said or.....jack up the car and put some 2x4's under it with the extension on top of them and lower the car onto the extension, its like hitting it with a hammer that weighs as much as the car. worked like a charm for me.
z6hatchboy
16
Aug 6, 2009 07:59 AM
AViciousTHRUST
Dec 6, 2006 12:11 AM
NSfit
34
Apr 4, 2006 01:04 PM
TEG777
Jul 21, 2005 01:12 AM
90AcuraIntegra04
Mar 31, 2005 07:50 PM
