oh god here we go
Old Jul 20, 2005 | 02:37 PM
Crimson_Tide's Avatar
Default oh god here we go
well i just finished swaping the Z6 into my '91 std hatch... i hook up the battery and go to start the car and all i here is the starter click... when i turn the key to acc i hear the pump priming but it doesnt shut off... and when i go to start the car the pump whines higher... i cant check CEL's because i swapped out my gauge cluster and ever since i did that the CEL light has acted funky even when everything was fine... i think my problem involves how i hooked up the starter(of course)... can anyone give me instructions on how to hook up the starter and where all the wires from the fuse box lead... thats another thing i wanted to check up on... thanks guys
-Josh
Old Jul 20, 2005 | 02:55 PM
Default Re: oh god here we go (Crimson_Tide)
anybody?
Old Jul 20, 2005 | 03:09 PM
Malgerus's Avatar
Check the main ground on the thermostat housing. Bet you forgot to put it on.
Old Jul 20, 2005 | 03:16 PM
Default Re: oh god here we go (Mr. S)
i belive i did... is this it right here?
also where does this connection go? it is by the fuse box on the passenger side
-Josh
Old Jul 20, 2005 | 03:25 PM
Skinflute22's Avatar
i belive that connection grounds out your starter and goes somewhere on the tranny....
Old Jul 20, 2005 | 03:28 PM
crx90rcr's Avatar
Default Re: (Skinflute22)
that should b the wire conected to the pos side of the battery and then it routes to the second conector in the fuse box.
Old Jul 20, 2005 | 03:34 PM
HiProfile's Avatar
Real dumb question, did you recharge the battery?
I'm taking my '90 lx's d16z6 harness out to retape it in a few days, I could take pix if you want. Sorry to hear, I dreaded facing such probs while I was putting it in.
Old Jul 20, 2005 | 03:38 PM
Default Re: oh god here we go (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Real dumb question, did you recharge the battery?
I'm taking my '90 lx's d16z6 harness out to retape it in a few days, I could take pix if you want. Sorry to hear, I dreaded facing such probs while I was putting it in.</TD></TR></TABLE>
Yes the battery is charged and yes that would be cool if you could do that... it would help out a lot... and as for the second connector on the fuse box... which one is that? is it the second from the front? no its not the starter ground... i already have that hooked up... where do i hook the starter up to? that is my main problem... thanks a lot guys for the help
-Josh
Old Jul 20, 2005 | 03:46 PM
Ronin150's Avatar
You should have a "T" shaped wire that starts at the pos battery. Goes to the starter and then the gold ring you had in your had goes to the pass fuse box.
I'm in the same problem but I can't find the other gold plug.
Old Jul 20, 2005 | 04:39 PM
Default Re: oh god here we go (Ronin150)
so the starter is connected directly to the battery? thanks a lot that helps eminsly(SIC)
-Josh
Old Jul 21, 2005 | 06:38 AM
ttt
Old Jul 21, 2005 | 08:08 AM
Rywire's Avatar
Um, why is your tps plug on your map sensor....
Old Jul 21, 2005 | 08:17 AM
menkio's Avatar
Default Re: oh god here we go (droppedcrxsi)
tps and map get switch SOOO many times, but yea thats a ground click, the click of ground doom.. i punch sharks.. anyways.. just go ape **** and ground everything you can, should work itself out 5 grounds later
Old Jul 21, 2005 | 11:01 AM
Chase's Avatar
Default Re: oh god here we go (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">just go ape **** and ground everything you can, should work itself out 5 grounds later</TD></TR></TABLE>
haha damn straight
Old Jul 21, 2005 | 11:03 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">Um, why is your tps plug on your map sensor.... </TD></TR></TABLE>
Yep,That is what I thought too...
Old Jul 21, 2005 | 02:33 PM
Default Re: oh god here we go (88DXCRX)
yeah i wasnt sure about that but that shouldnt affect whether or not my car cranks over right? my friend came over for a few minutes before he went to school and messed with the starter... whenever he bridged the + and - terminals nothing would happen... actually the only thing that happened was a clicking sound came from either the middle two connectors or something underneath the intake manifold... why is it doing that? im going to go ground everything i can and switch the tps and map sensor connectors... thanks again guys and if theres anything else you can think of either post on here or call my cell... 419-233-2041
-Josh
Old Jul 21, 2005 | 03:09 PM
EFbomb's Avatar
Im guessing, but it would do this
First of all, make sure the wiring into the fuse box is correct, that wire needs to be grounded. i think there might be a ground that bolts near the braket that holds the brake lines under/near the fuse box.
1.) replace the battery with a known good one(out of a running car) or brand new one.
1.5)check the clutch switch
2.)check the ecu connections
3.)make sure your battery terminals arent backwards
4.)is the starter jammed?(take a long *** screwdriver, put it on the starter part next to the tranny, and whack it a few times with a hammer. or take it out, but leave it plugged in and see if the bendix kicks out the gear(turn the key and see if it pops out when it spins, whie a good friend wearing cloves holds it away from anything)
make sure the wires in the fuse box are corectly in place and there arent any fuses bad.
just my guesses
Old Jul 21, 2005 | 10:04 PM
Default Re: (EFbomb)
thanks a lot man... turns out i had a few wires switched and all of my grounds sucked... so after i got all those figured out the motor slowly cranked over and finally after a few tries it cranked like normal and fired!! so much smoke came out that when my girl opened the door about 30 sec. later to see what was going on the fire alarm went off... lol anyways she runs perfect and i found out that the clutch and flywheel are aftermarket because it revs like a bike(almost) and the clutch grabs instantly... i couldnt be any more happy with this... i ran it around the block real quick and i didnt have the speed cable in so there was no vtec and it still felt fast!! lol now that ive hooked the speed cable up im going to go drive around for a little bit and then go up against my buddies b18 eg ... ill let you know the results... thanks so much guys for the help!!!!!!!!!!!!!!!!!
-Josh
Old Jul 21, 2005 | 10:11 PM
ecovillain's Avatar
Default Re: (Crimson_Tide)
wait..so does your fuel pump still not shut off after priming like normal?
bump cause im having this issue as well...z6 in an 89 hatch...cept mine runs fine.
Old Jul 21, 2005 | 10:17 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (ecovillain)
The ground in your hand looks like the one for the fuse box on the right hand side of the car. If you have that hook up already like everyone has mentioned its for the starter bolt 12mm.
Old Jul 22, 2005 | 12:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ecovillain &raquo;</TD></TR><TR><TD CLASS="quote">wait..so does your fuel pump still not shut off after priming like normal?
bump cause im having this issue as well...z6 in an 89 hatch...cept mine runs fine.</TD></TR></TABLE>
no it doesnt anymore... not since ive rewired... car runs excellent now... i ran right along side my buddy in his eg but he ended up pulling me by about half a car in the end
-Josh
Old Jul 24, 2005 | 04:14 PM
ecovillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide &raquo;</TD></TR><TR><TD CLASS="quote">
no it doesnt anymore... not since ive rewired... car runs excellent now... -Josh</TD></TR></TABLE>
what all did you re-wire?
please help me out, im trying to figure this out.
Old Jul 24, 2005 | 08:50 PM
i just redid all of the grounds and switched the plugs that go to the tps and the iacv... after that i never had a problem... this is just a shot in the dark but you might want to try to do that and if that doesnt work i would just redo all of the wiring and make sure that it is all correct... any other questions just ask
-Josh
B_Swapped93
Jun 3, 2013 04:24 PM
97civic07gsxr
21
Feb 8, 2009 02:33 PM
vroompsshht
Sep 14, 2006 05:07 PM
CRX7
Aug 29, 2005 01:42 PM
TurboTeG4
Nov 24, 2004 11:19 AM
