Where to get fittings for my oil cooler?
Old Jul 20, 2005 | 12:47 PM
mike1114's Avatar
Default Where to get fittings for my oil cooler?
I need two fittings that are 3/4-16 sae to screw onto the oil cooler, and the other end needs to be for a hose that I can use clamps on.
Does anyone know where to get these?
I found this on the internet, are these the correct fittings?
http://www.char-lynn.com/everf...1.htm
Thanks!
Old Jul 20, 2005 | 01:32 PM
IN VTEC's Avatar
Default Re: Where to get fittings for my oil cooler? (mike1114)
You probably need a pair of -8AN o-ring port to -8AN flare adapters and then a pair of -8AN socketless hose-ends.
Old Jul 20, 2005 | 02:14 PM
B-twentyVTEC's Avatar
Default Re: Where to get fittings for my oil cooler? (IN VTEC)
here you go.. http://www.racerpartswholesale.com/
thats where I ordered mines.. click on catalog on the left hand side.. and scoll down to the main window.. look for fittings.. then adapters.. their cheap.. and good quality...
Old Jul 20, 2005 | 02:15 PM
mike1114's Avatar
Y U say that?
Here is a link to the oil cooler I got from egay.
http://cgi.ebay.com/ebaymotors...87031
Old Jul 20, 2005 | 02:22 PM
not bad .... for that oil cooler
Old Jul 20, 2005 | 02:58 PM
mike1114's Avatar
Default Re: (Mr_WETTY)
thanks!!
everyone is pointing out AN fittings, is 3/4-16 sae equivalent to some AN fittting?
Old Jul 20, 2005 | 04:53 PM
mike1114's Avatar
Default Re: (mike1114)
Bump
Old Jul 20, 2005 | 05:00 PM
s2kdre's Avatar
did u try hydraulic supply? they are on west 50
Old Jul 20, 2005 | 05:15 PM
IN VTEC's Avatar
3/4"x16 is the standard thread for -8AN flare and port fittings.
Try a pair of Earl's 985008ERL,
http://www.amstreetrod.com/985008ERL.php4
coupled with Earl's 709109ERL (90 deg) and/or 704609ERL (45 deg) and/or 700109ERL (straight) hose-ends.
http://www.amstreetrod.com/709145ERL.php4
http://www.amstreetrod.com/700145ERL.php4
Old Jul 20, 2005 | 05:16 PM
mike1114's Avatar
Default Re: (jdmhonda)
I'mma call them tomorrow.
ShawnR
May 11, 2007 01:07 AM
Speedra500
Jun 28, 2004 01:33 PM
Weston
May 12, 2004 10:12 PM
5-SpeedFreak
Mar 26, 2002 03:01 PM
