00-01 Type R header on 00 GSR...?
Old Feb 17, 2002 | 11:27 PM
RuskeR's Avatar
Default 00-01 Type R header on 00 GSR...?
Will this fit without modifying anything? Also, what are the differences between the two? Will there be any noticable gains at all? Searched for awhile but, didn't find anything about any gains from adding the type r header. thanks.
Old Feb 17, 2002 | 11:30 PM
comptechgsr's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (RuskeR)
gotta modify the exhaust/cat
Old Feb 17, 2002 | 11:33 PM
RuskeR's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (comptechgsr)
See I read that in one post but, the next post I read says you do unless you have a 2000-2001 GSR. Any ideas on that? Weren't the 00-01 exhausts alittle different? I'm not completely sure of all changes made throughout the different years.
Old Feb 17, 2002 | 11:53 PM
CKim's Avatar
Dino (comptechgsr) is wrong. It will fit. No modifications necessary.
Trust me (I own a '00 GS-R).
Old Feb 18, 2002 | 01:12 AM
StinkyTofu's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (CKim)
yeup it'll fit. all 00-01 GSR's have the same cat length and b-pipe length as all ITR's and LS/GS/RS.
Old Feb 18, 2002 | 01:59 AM
B18CRacer's Avatar
of course it will fit....its on my car. gains is not much about 5hp
Old Feb 18, 2002 | 10:23 PM
g's integ's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (B18CRacer)
Will it fit on my '95 LS w/ b16a top n b18c bottom?
Old Feb 18, 2002 | 10:26 PM
RedStarGsr's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (g'sinteg)
the primaries will bolt up to your head, but dont count on the collector fitting up w/ your cat, you're going to either
A. go to a muffler shop and have them make you a connector piece w/ flanges ( $$ )
B. Have someone weld it ( muffler shops can do this.....but charge )
Old Feb 18, 2002 | 11:07 PM
g's integ's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (RedStarGsr)
Someone brought this up re to the ITR exhaust matching up. Why does it have no prob if you have an LS cat bolting to a ITR cat-back muffler but headers don't match up? Any other suggestions? much appreciations
[Modified by g'sinteg, 8:09 AM 2/19/2002]
Old Feb 18, 2002 | 11:26 PM
Mike M's Avatar
Founding Member
97-01 Type R header on 00-01 GSR will bolt right on, same size and length Will also Fit, 94-01 LS, RS, or GS
Old Feb 18, 2002 | 11:30 PM
92TypeR's Avatar
FSAE
the us itr headers will fit, the jdm 4-1 itr headers need a special 2.5 inch collector flaunge to fit the cat. So yes AND no. Depends on which u wanna get, the jdm itr will give more power, the usdm itr is a good substitute for stock.
Old Feb 27, 2002 | 07:20 AM
g's integ's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (92TypeR)
What's the difference between the stock GS-R and ITR header?
Old Feb 27, 2002 | 08:49 AM
red97gsr's Avatar
Stock GSR's don't have a header, just a cast iron manifold.
Old Feb 27, 2002 | 09:09 AM
YellowSpeed's Avatar
New User
Default Re: 00-01 Type R header on 00 GSR...? (red97gsr)
Does any one want to buy and USDM ITR header?
Old Feb 27, 2002 | 09:20 AM
BSQ's Avatar
BSQ
They both have a cast iron upper section. It is the A-pipe which is different. Here is a diagram which shows the difference.
Old Feb 27, 2002 | 09:52 AM
threatcon13's Avatar
New User
exhaust manifold=header.
Old Feb 27, 2002 | 06:32 PM
Comtechgsr2000s's Avatar
New User
Default Re: 00-01 Type R header on 00 GSR...? (ALLMOTORDC2)
It will be a direct bolt on without any modifications.
All Type R. 2000-01 gsrs, and 94-01 non vtecs are all the same size.
Old Feb 27, 2002 | 09:06 PM
t's Avatar
t
Yes
Old Feb 28, 2002 | 08:09 AM
g's integ's Avatar
Default Re: 00-01 Type R header on 00 GSR...? (t)
coo thanks guys
Old Feb 28, 2002 | 11:48 AM
deep6's Avatar
hey fellas:
does anybody have pics of their car w/ the "R" header bolted up to the stock GS-R cat on the 94-99 models in which you are supposed to modify inorder for it to fit...would like to see what needs to be modified??? also where did you guys purchase this USDM type r header from and how much did it cost?
any info. or help would be much appreciated.
thank you.
STUCKED
Feb 22, 2005 09:58 AM
EKtypeRhaTcH
Nov 29, 2004 12:48 PM
BlueIntegraBoy
Jul 30, 2003 05:56 AM
jdm pwr
Jun 28, 2003 02:25 PM
PolySquared
May 25, 2003 12:13 AM
