should be an easy question for u guys
Old Jul 20, 2005 | 08:04 AM
VINtegra90's Avatar
Default should be an easy question for u guys
i think theres something wrong with my alternator. after the car sits for a little while it wont start. seems to be getting worse the past couple of days. my radio wasnt working last night unless i was driving fast. does this sound like an alternator problem?
Old Jul 20, 2005 | 08:37 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: should be an easy question for u guys (VINtegra90)
How old is your battery?
Old Jul 20, 2005 | 08:40 AM
Sack Master's Avatar
Default Re: should be an easy question for u guys (shamoo)
Could be your battery too. Not holding a charge. I would get out the volt meter and check it before you decide you need a new alternator.
Old Jul 20, 2005 | 08:57 AM
Deep's Avatar
Default Re: should be an easy question for u guys (Sack Master)
Unplug your + off the battery and if it stays on your alternator is fine.
Old Jul 20, 2005 | 09:06 AM
Backk InTheDA's Avatar
I hate everything
Default Re: should be an easy question for u guys (Deep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deep &raquo;</TD></TR><TR><TD CLASS="quote">Unplug your + off the battery and if it stays on your alternator is fine. </TD></TR></TABLE>
Yeah do this, when my alternator went, i noticed that my dash lights were extremely dim, and when i used my windsheild wipers on the fastest speed, that would just crawl across the window.
Your alternator doesn't kick in til about 1k on the tach, and when i would start mine, and it would fall below 1k, my battery light would flicker on/off until i gave it gas, but i decided to drive it, and it died on me on the freeway, so i go to use my turn signals, no power, so ofcourse they dont work.
So, im thinking to myself, well i need to signal, so i go to roll down my windows, oh wait, all teg's have power window's, lol, i owned myself.
No but seriously, do what Deep suggested
Old Jul 20, 2005 | 09:33 AM
VINtegra90's Avatar
Default Re: should be an easy question for u guys (BuilttB18C5)
hmm good suggestions.. im gonna take a look at that right now. the battery is like a month old. my negative terminal connection on my battery isnt tight. my dad said that isnt good, but i dont think that would cause this to happen. ill try the + terminal trick now.
Old Jul 20, 2005 | 09:34 AM
VINtegra90's Avatar
my car dont have pw 2gen
Old Jul 20, 2005 | 09:54 AM
VINtegra90's Avatar
okay i did the test, i had my key in the two position and unplugged the + terminal of the battery and the car turned off. this means my alternator is dead??? car started up alright though.
Old Jul 20, 2005 | 10:06 AM
VINtegra90's Avatar
help pleasssssssssssssssssssse
Old Jul 20, 2005 | 04:03 PM
calxtreme's Avatar
sounds like the alternator then. I assume your battery drained out, so you charged it, but when you run your car the battery light still stays on? You can also take your car to kragens or something and they can test it for your or you can do it yourself by tapping it with a multimeter.
Old Jul 20, 2005 | 05:24 PM
freakasis's Avatar
if you unplugged the + terminal and it dies...then its either yer alternator or some wiring problems. take the alternator to advance or discount. they can test it for ya for free. then youll know. if its bad that its the problem, if its fine that its wires. prolly not the wires though unlesss they are held together with tape and glue. hehe
Old Jul 21, 2005 | 06:45 AM
VINtegra90's Avatar
Default Re: (freakasis)
did i do the test right though or was i supposed to start the car before i unplugged the terminal? i only had it in the two position. i tried some other test someone said. with my car off the meter said 12 and with it on it said close to 14. i think thats the way its supposed to be? i guess ill go test it. thx for the help so far.
most important thing id like to kno: it's DEFINITELY either the alternator or the wires connected to it, right?
Wiretaju
Jun 25, 2010 03:02 PM
BoltonGSR
Jul 7, 2008 08:27 PM
obuhmyuh
May 28, 2008 03:27 PM
C-A
Oct 1, 2007 07:17 PM
Slammed Ek9
May 2, 2005 12:06 PM
