Switching from a t3/t4 on drag mani to a gt28rs
is there alot that needs to be changed to fit this turbo? and what is up with the wastegate mounted on to it? any info would help thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR »</TD></TR><TR><TD CLASS="quote">is there alot that needs to be changed to fit this turbo? and what is up with the wastegate mounted on to it? any info would help thanks</TD></TR></TABLE>
The flange of the wastegate will need to be EFFECTIVELY welded shut, and you must find a T3---T2 flange conversion for it, which may seat the turbo a little lower.
It might be a better idea to get the inexpensive HKS manifold.
I would go with the t3/t4 style drop-in available from atpturbo.com. I think you'll be needing an oil restrictor and run your lines for water cooling. Best of luck as I'd love to upgrade to that turbo also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI »</TD></TR><TR><TD CLASS="quote">I would go with the t3/t4 style drop-in available from atpturbo.com. I think you'll be needing an oil restrictor and run your lines for water cooling. Best of luck as I'd love to upgrade to that turbo also.
Aye, you'll be needin a banjo fittin...arggh. And water cooling lines as well.
</TD></TR></TABLE>Aye, you'll be needin a banjo fittin...arggh. And water cooling lines as well.
jeffcommanche
Dec 8, 2001 11:31 AM
