Cam Tuning noob question
Old Jul 20, 2005 | 03:55 AM
Takumi Fujiwara's Avatar
Default Cam Tuning noob question
After you change the settings on the cams... are you supposed to re-set/do the timing?
Old Jul 20, 2005 | 08:26 AM
Outsane's Avatar
Default Re: Cam Tuning noob question (Takumi Fujiwara)
if your messing with the cams you should be on a dyno
Old Jul 20, 2005 | 08:27 AM
IN VTEC's Avatar
Only if you move:
intake cam (B-series)
exhaust cam (H-series)
It depends on which cam drives the distributor, where the crank angle sensor is located.
Old Jul 20, 2005 | 10:26 PM
Default Re: Cam Tuning noob question (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Only if you move:
It depends on which cam drives the distributor, where the crank angle sensor is located.</TD></TR></TABLE>
Makes sense. Thanks.
johnclaunch
Apr 3, 2008 09:27 AM
drumminforev
Nov 21, 2006 07:50 PM
93b20z
Oct 11, 2006 07:28 PM
Mr.Integra
Apr 10, 2003 01:39 PM
Comptech98GSR
Oct 10, 2001 01:42 AM
