HELP: Bad torque converter or tranny?
Old Jul 19, 2005 | 11:55 PM
CivicNewbie's Avatar
Default HELP: Bad torque converter or tranny?
I recently have some prob with my 97 accord, I hope I can get some help in here. It can get into any gears just fine, but no movement. When you let it cools down for a long period of time (about 2 hrs or so) it works fine in every gears but can only go for about 20 yards then it just acts like it's in neutral.
The fluid level was fine but really dirty, and I just changed the fluid with HONDA ATF and it still acts the same. Anyone know what go wrong with my car? TIA
Old Jul 19, 2005 | 11:59 PM
hawkimport's Avatar
Default Re: HELP: Bad torque converter or tranny? (CivicNewbie)
with out testing, I would have to say trany time.
you know that there are codes that are thrown from the TRANY CM (control mod)
Might want to try to pull those, but from what I have seen from tranys in the past, its time to replace that bad boy.
Good luck
Old Jul 20, 2005 | 07:30 AM
raceACCORDingly's Avatar
i think your clutch packs are toasted. if you need a torque converter i got a mint on ill let go for cheap..
Old Jul 20, 2005 | 07:47 AM
Default Re: HELP: Bad torque converter or tranny? (hawkimport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawkimport &raquo;</TD></TR><TR><TD CLASS="quote">with out testing, I would have to say trany time.
Good luck</TD></TR></TABLE>
I got code 15 from the tranny CM which is mainshaft speed sensor. But after fluid changed & reset there's no code.
Old Jul 20, 2005 | 07:49 AM
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">i think your clutch packs are toasted. if you need a torque converter i got a mint on ill let go for cheap..</TD></TR></TABLE>
Is it normal to have 2 clutch packs toasted at the exact sametime?
Old Jul 20, 2005 | 11:42 AM
drifter_for_life06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">i think your clutch packs are toasted...</TD></TR></TABLE>
i agree
Old Jul 21, 2005 | 07:20 AM
Default Re: (drifter_for_life06)
thanks for all yours help, I'll put my new tranny on this weekend.
stat3ofm1nd
10
Sep 24, 2012 01:22 PM
stevescivic
Apr 12, 2007 03:58 PM
phateless
Sep 9, 2005 03:12 PM
NewfieAccordEXR
Aug 10, 2005 06:43 PM
TwoPointZero
Nov 18, 2004 04:12 PM
