Camshaft Install
Old Jul 19, 2005 | 11:19 PM
SenseiAccord's Avatar
Default Camshaft Install
I was wondering what do i need to do and/or replace in order to install a camshaft correctly. I have a 1990 Honda Accord with stock SOHC motor. I know i need to use camshaft assembly lube but what else do i need to do. Do Hondas even have lifters to replace? Thanks honda techs!
Old Jul 22, 2005 | 06:27 PM
onepoint6i's Avatar
Default Re: Camshaft Install (SenseiAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SenseiAccord &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering what do i need to do and/or replace in order to install a camshaft correctly. I have a 1990 Honda Accord with stock SOHC motor. I know i need to use camshaft assembly lube but what else do i need to do. Do Hondas even have lifters to replace? Thanks honda techs!</TD></TR></TABLE>
no we dont have lifters, the cam rides on the rockers Thus SOHC (over head cam)
you have to adjust the valve lash after installing the cam, considering your installing a performance cam..if your installing a stock cam..i would still check all the lashes after install.......get a service manual for install instructions..
Old Jul 22, 2005 | 07:38 PM
slomofo's Avatar
GDD Member
Valve adjustment specs are listed on the sticker underneath your hood as well.
the king.
Jun 21, 2008 01:39 PM
matt j
Sep 2, 2004 06:05 PM
turbob18a1
Jun 28, 2003 11:55 PM
acatak
Jan 23, 2003 09:39 PM
Briman2021
Feb 25, 2002 05:33 PM
