cel light is on...car wont start...need help asap
ok so my 93 EX is somehow messed up. the cart wont start at all. it WILL turn over however but it will not start. i just put in a brand new battery today and then while at my grandmothers it wouldnt start.i tired for hours to see what might be wrong. after consulting the haynes manual and a fellow honda fimilar friend, we cam to the conclusion that my spark plugs are messed up and i need new ones. something in my fuel injection system, and/or my regulator. i dont really know what is wrong specifically. ANY and all advice is needed. tommorow i plan on replacing the spark plugs all together but could there be a different problem?
before replacing plugs do a couple of things
# 1 find out the code
# 2 diagnose why car wont start ............are you getting fuel?? are you getting spark????..........how did you come to the conclusion that the spark plugs are messed up????? they could be badly fouled because of all thew cranking you have been doing ......
if you are not getting fuel.. chk out the main relay
if no spark could be ignitor, coil, rotor ... but since you said chk engine lite is on i would chk out the code first
Blue_Si03
Mar 20, 2003 11:10 AM
