Looking for 60 trim turbine specs....I've searched
I'm looking for the spec's of a garrett t3/t4 .60/.63 60 trim turbo stage III wheel. I'm trying to find out the size of the wheel inducer,wheel exducer, for the turbine side. I've tried searching and didnt find the info I was looking for. I need this info because I have the turbo described above with a 4 bolt discharge flange and I want to get a 5 bolt .63 discharge turbo housing. does anyone how which precision housing I can use or where I can get a garrett 5 bolt. Any info will be greatly appreciated.
http://www.cheapturbo.com has 5 bolt garrett housings for like 60 bucks but i think u need to ship ur turbo to them.
2.229" / 2.559"
there is no reason you'd need to ship your turbo to them and I can't imagine the housing is only 60 bucks.
bump for more info. looking for the wheel diameter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marshall »</TD></TR><TR><TD CLASS="quote">2.229" / 2.559"
there is no reason you'd need to ship your turbo to them and I can't imagine the housing is only 60 bucks.</TD></TR></TABLE>
I compared those spec's to the precision turbos and it looks like the sc-34 uses the same size turbine housing
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">the offer a 5 bolt housing UPGRADE for 60 bucks when you purchase a turbo from them.......
if you purchase a turbo from them.. which he obviously is not. i can get the housings for 110, which is pretty damn cheap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">
if you purchase a turbo from them.. which he obviously is not. i can get the housings for 110, which is pretty damn cheap</TD></TR></TABLE>
I pm'ed you
I pm'ed you
SCV_GSR
Nov 25, 2009 07:28 AM
themazdak
Apr 17, 2008 01:16 AM
blueturbo4door
May 3, 2005 08:00 PM
c4sp3r
Jun 1, 2004 07:43 PM
