Looking for 60 trim turbine specs....I've searched
Old 07-19-2005, 06:21 PM
D-tuned's Avatar
Default Looking for 60 trim turbine specs....I've searched
I'm looking for the spec's of a garrett t3/t4 .60/.63 60 trim turbo stage III wheel. I'm trying to find out the size of the wheel inducer,wheel exducer, for the turbine side. I've tried searching and didnt find the info I was looking for. I need this info because I have the turbo described above with a 4 bolt discharge flange and I want to get a 5 bolt .63 discharge turbo housing. does anyone how which precision housing I can use or where I can get a garrett 5 bolt. Any info will be greatly appreciated.
Old 07-19-2005, 06:26 PM
VtecAdil's Avatar
http://www.cheapturbo.com has 5 bolt garrett housings for like 60 bucks but i think u need to ship ur turbo to them.
Old 07-19-2005, 06:28 PM
D-tuned's Avatar
Default Re: (VtecAdil)
thanks for the help. I tried to call them today and no one picked up the phone. I will trying again tomorrow.
Old 07-19-2005, 07:20 PM
Marshall's Avatar
Default Re: Looking for 60 trim turbine specs....I've searched (gsrcivicsi)
2.229" / 2.559"
there is no reason you'd need to ship your turbo to them and I can't imagine the housing is only 60 bucks.
Old 07-19-2005, 07:25 PM
non-VTEC's Avatar
Default Re: Looking for 60 trim turbine specs....I've searched (Marshall)
the offer a 5 bolt housing UPGRADE for 60 bucks when you purchase a turbo from them.......
Old 07-20-2005, 02:35 AM
D-tuned's Avatar
Default Re: Looking for 60 trim turbine specs....I've searched (non-VTEC)
bump for more info. looking for the wheel diameter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marshall &raquo;</TD></TR><TR><TD CLASS="quote">2.229" / 2.559"
there is no reason you'd need to ship your turbo to them and I can't imagine the housing is only 60 bucks.</TD></TR></TABLE>
I compared those spec's to the precision turbos and it looks like the sc-34 uses the same size turbine housing
Old 07-20-2005, 05:51 AM
Who is Mr Robot?
wantboost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the offer a 5 bolt housing UPGRADE for 60 bucks when you purchase a turbo from them.......
if you purchase a turbo from them.. which he obviously is not. i can get the housings for 110, which is pretty damn cheap
Old 07-20-2005, 07:30 AM
D-tuned's Avatar
Default Re: Looking for 60 trim turbine specs....I've searched (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
if you purchase a turbo from them.. which he obviously is not. i can get the housings for 110, which is pretty damn cheap</TD></TR></TABLE>
I pm'ed you
b18cgsrturbo
06-09-2015 03:30 PM
SCV_GSR
11-25-2009 07:28 AM
blueturbo4door
05-03-2005 08:00 PM
c4sp3r
06-01-2004 07:43 PM
Quick Reply: Looking for 60 trim turbine specs....I've searched
