**<<<<<< cam gears on a turbo setup with a 2mm headgasket... >>>>>&
Old Jul 19, 2005 | 06:05 PM
blacktegmd's Avatar
Default **<<<<<< cam gears on a turbo setup with a 2mm headgasket... >>>>>&
has anyone here used a thick(er) headgasket and not used adjustable cams gears to make up for the small extension of the block ?
I`am using a 2mm headgasket in a G-sr ( b18c1 ) build and haven`t bought my cam gears yet.. i have everything else, i want to make a appearence at a drift show saturday.. i haven`t installed the motor and i have everything for it... how many people here have used the stock cam gears ? and how many have done so with no problems ?
Old Jul 19, 2005 | 07:02 PM
blacktegmd's Avatar
Default Re: **<<<<<< cam gears on a turbo setup with a 2mm headgasket... >>>>&
has anyone ever put a thicker headgasket on their Gs-r ???? let me know if you HAD to change the cam gears...
EGtypeR408
May 28, 2011 05:05 PM
EGunit
Aug 5, 2007 11:23 PM
Sir-Boost-Alot
Oct 26, 2005 02:00 PM
Smoochy
Mar 28, 2003 04:06 PM
vtec_powah
Jun 17, 2001 06:32 PM
