LS ROD ARP ROD BOLTS?????????????
Old Jul 19, 2005 | 05:50 PM
REEMB18C1's Avatar
Default LS ROD ARP ROD BOLTS?????????????
if i use arp rod bolt do i have to resize my rods??????????? building a motor
Old Jul 19, 2005 | 06:10 PM
DonF's Avatar
Default Re: LS ROD ARP ROD BOLTS????????????? (REEMB18C1)
yes. diff. torque, diff stress.
Old Jul 19, 2005 | 06:38 PM
REEMB18C1's Avatar
Default Re: LS ROD ARP ROD BOLTS????????????? (DonF)
SO I WOULDNT BE ABLE TO USE STOCK BEARINGS I WOULD ALSO HAVE TO RESIZE MY CRANK JOURNAL CORRECT ??????
Old Jul 19, 2005 | 06:42 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REEMB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">SO I WOULDNT BE ABLE TO USE STOCK BEARINGS I WOULD ALSO HAVE TO RESIZE MY CRANK JOURNAL CORRECT ??????</TD></TR></TABLE>
As far as I know, No! You should still be able to use the same size bearings as before.
Old Jul 21, 2005 | 05:19 AM
boosted k20's Avatar
Default Re: LS ROD ARP ROD BOLTS????????????? (hybrid_vtec)
once u get the new arp rod bolts pressed in, the machine shop will have to hone the rods to make them a perfect circle. and u can still use the stock bearings (no need for oversize bearings) and u dont need to do anything to the crank. i put arps in my LS rods, had them resized the rods, put in ACL bearings and checked the clearances on the crank. everything was perfect. just plastigage the crank when u install everything
Old Jul 21, 2005 | 04:09 PM
REEMB18C1's Avatar
Default Re: LS ROD ARP ROD BOLTS????????????? (boosted k20)
good look !!!!!!!!!!!!!!!!
blkdoutteg
Aug 14, 2014 08:06 AM
lriver0001
Apr 29, 2011 07:10 AM
viera
Feb 19, 2010 12:09 PM
94civickid
Mar 15, 2005 02:10 PM
HX_Guy
Jul 20, 2001 07:30 AM
