B16a Help
Old Jul 19, 2005 | 05:48 PM
4drsleeper123's Avatar
Default B16a Help
I just got a b16 swap from a guy that a friend new, well I got the swap home and I took out the spark plugs to see if they where any good and got to looking in the cylinder and seen that there was water or oil in the cylinder. What is wrong with the motor and how could I go about fixing it? This is why you dont buy swaps from people you dont know they will do you wrong everytime!!!!!!!!!
Old Jul 19, 2005 | 06:12 PM
RedEj8's Avatar
Default Re: B16a Help (4drsleeper123)
Sometimes people will put a little oil in the cylinders to keep everything from rusting and ****..Maybe its that?
Old Jul 19, 2005 | 07:18 PM
Default Re: B16a Help (reddohcvtec)
Man I hope so!!!!! Thanks for the help keep it comin please
Old Jul 19, 2005 | 07:44 PM
bigdaddyradde's Avatar
was it water or was it oil?
Old Jul 19, 2005 | 08:36 PM
Default Re: B16a Help (bigdaddyradde)
I could not tell I hope that is was oil but I really could not tell. When I pit my screw driver down in the head it looked like oil but smelled funny(not like oil). It was only in one cylinder not all four that makes me think that it was not done by the person I got it from.
Old Jul 19, 2005 | 10:31 PM
BUMP
Old Jul 19, 2005 | 11:05 PM
AnDThEnWuT's Avatar
pull the head and inspect the whole motor.
Old Jul 19, 2005 | 11:25 PM
Default Re: B16a Help (AnDThEnWuT)
I dont want to do that because the seal has never been broken from stock yet, but it looks like that is what Im going to have to do I wil post up what is all wrong with it tomorrow. Thanks for all the help pray for me
Old Jul 19, 2005 | 11:34 PM
EG-SI(rII)'s Avatar
If it looks like coffee then there's most likely water in there. I wouldn't recommend buying anything from guys your friends know anymore.
Old Jul 20, 2005 | 07:56 AM
Default Re: B16a Help (EG-SI(rII))
I dont think that I will!!!!!!!!! So if it is water how bad is it to fix, or can you even fix it.
Old Jul 20, 2005 | 08:17 AM
B18CR_EJ2's Avatar
seeing as there is only oil in one of the cylinders, im going to agree that this isnt something that the user did before. some potential problems could be that one or more of your valves isnt sealed properly or there could be a crack in the head over top of that cylinder.... not really sure it could be a couple of things and there isnt a way to know with out removing the head.... sorry man good luck. call japan direct 1-919-781-7314 for further technical support...
Old Jul 20, 2005 | 11:32 AM
Default Re: B16a Help (B18CR_EG)
sole4dayz
Sep 20, 2010 12:01 PM
accord2nrz
Nov 28, 2009 03:38 AM
RanCRX
Nov 8, 2007 04:47 PM
NA JDM GSR
Oct 22, 2006 06:17 AM
lojackgsr
Apr 26, 2006 02:45 PM
