do i need a resistor box if i'm obd1 on my91 civic si
Old Jul 19, 2005 | 04:11 PM
racingant's Avatar
Default do i need a resistor box if i'm obd1 on my91 civic si
ok this is my setup i have a 91 civic si a jdm b16 swap that is converted to obd1 and this is what i converted. i'm using obd1 b16 injector with obd1 plugs,obd1 ls dist now what i did was i cut the plug off the ls dist and put on a 91 civic si plug on so i can use my 91 civic si harness, gsr ecu obd1 and the boomslang obd0-obd1 ecu conversion jumper. now do i still use my resistor box or no, i was told that i don't need my resister box.
what do i do with the wires that was going to the resister box and would this make my car run like **** meaning it will ake long for the car to start and when it do start it idles rough. when i give it gas the car cuts off, right now i still have the resistor still pluged in.
Old Jul 19, 2005 | 05:06 PM
NikoZai's Avatar
Default Re: do i need a resistor box if i'm obd1 on my91 civic si (racingant)
OBD1 injectors require 12 volts. They need this:
or to be all soldered together - the ghetto way
OBD0 injectors require 5.5 volts and use a injector resistor box to change the voltage to 5.5
Old Jul 19, 2005 | 05:09 PM
racingant's Avatar
Default Re: do i need a resistor box if i'm obd1 on my91 civic si (NikoZai)
do i have to run one wire to the other harnees plug to get the 12v to the injector
Old Jul 19, 2005 | 05:30 PM
racingant's Avatar
with the dist what i did was put the obd0 plug on the b series ls dist is that ok or do i have to get the 92-95 plugs
Old Jul 19, 2005 | 07:23 PM
racingant's Avatar
bump
accordin 2 me
Dec 12, 2011 05:05 PM
95_red_dc
Jun 17, 2006 08:55 PM
ef9ontime
May 28, 2006 01:23 PM
racingant
Sep 28, 2005 05:10 PM
JDMCivicEF9
19
Sep 6, 2003 11:00 AM
