Headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze »</TD></TR><TR><TD CLASS="quote">so will a type r headgasket fit a b16?</TD></TR></TABLE>
type r integra? No. it has a b18
Are you trying to put a used head gasket on your car?
If that is what you are trying to do don't even bother. It will blow within the first 100 miles. Bite the bullit and buy a head gasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze »</TD></TR><TR><TD CLASS="quote">no..i have a type r headgasket for b18c5 but can i put it on a b16a?? no ones giving me a clear answer to my question.......</TD></TR></TABLE>
I just said no four times. How much clearer does it need to be? Do I need to drive to your house, kick you in the nuts, burn the head gasket, and then force you to get an outline of my nuts tattooed on your chin?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">I think he is looking for.......<FONT SIZE="20">NO</FONT></TD></TR></TABLE>
I'm aware, and I think I made it pretty clear in my previous posts.
yes you can use this on a b16 engine, the bores should be the same for OEM it should be around 81mm. B18 and 16 pistons share the same bore. In my b18 i used type R HG with a B16 head. so im sure it works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toxidomask »</TD></TR><TR><TD CLASS="quote">yes you can use this on a b16 engine, the bores should be the same for OEM it should be around 81mm. B18 and 16 pistons share the same bore. In my b18 i used type R HG with a B16 head. so im sure it works. </TD></TR></TABLE>
I believe this is correct... both Mugen and Spoon list ALL DOHC VTEC head gaskets as having the same part #. I have a Spoon head gasket for an ITR on my B16. It's been on there for about 2 years now and I've yet to have any problems at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
I just said no four times. How much clearer does it need to be? Do I need to drive to your house, kick you in the nuts, burn the head gasket, and then force you to get an outline of my nuts tattooed on your chin?</TD></TR></TABLE>
your the biggest ****** ******...i just asked if it will fit..yes or no not your bullshit extended answers...i never asked anything else..its was a clearly stated question so why can you give me a yes or no and not be a douche bag like you are? dumbass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">No. The fire rings on a B18 head gasket will be bigger than a B16 and smaller than a B20.</TD></TR></TABLE>
You're a fountain of misinformation.
Maybe you should stop posting.
An ITR headgasket will work fine on your B16.
your the biggest ****** ******...i just asked if it will fit..yes or no not your bullshit extended answers...i never asked anything else..its was a clearly stated question so why can you give me a yes or no and not be a douche bag like you are? dumbass</TD></TR></TABLE>
Hahaha....and that guy was wrong anyways! You can use it for your engine.
I'm aware, and I think I made it pretty clear in my previous posts. </TD></TR></TABLE>
All you made clear in your previous posts is that you don't know WTF you're talking about... we get it... you've much left to learn....
...you have a good day now little boy!!!
Check your **** before you start bashing people with your miss-*******-information please.
LOL..i knew they had the same 81 mill bore but i wasnt 100% sure..till this douche bag made me check twice..thanks to all who actually answered my ?
