Suggestions needed for possible electrical problem
Old Jul 19, 2005 | 11:47 AM
Modern Intellect's Avatar
Default Suggestions needed for possible electrical problem
Due to over revving, my stock 91 civic hatchback seriously overheated to the point that the manifold was visibly red. We found that the timing belt had become loose possibly causing it not to start? Timing belt has been tightened and timing has since been advanced. On attempting to start the engine, it seems to turn over properly and without any noise or clanks that may indicate internal engine damage, but the engine will not start. Spark plugs are fine. What factors in the electrical system may be damaged due to overheating that may result in this problem? Or could something else be causing this?
Thanks for the help!
Old Jul 19, 2005 | 11:56 AM
purplecrx's Avatar
Did you check to make sure the timing belt didn't jump a tooth? I'm assuming you did when you tightened it.
green_si
18
Mar 3, 2010 03:24 PM
Jack Shephard
12
Feb 13, 2009 06:27 PM
ammccrea
Oct 25, 2005 11:23 AM
WillyD6869
Jun 13, 2005 11:46 AM
90CIVICSI
Jul 7, 2002 08:49 PM
