Energy Suspension motor mounts...
Old Jul 19, 2005 | 10:19 AM
luderchris's Avatar
New User
Default Energy Suspension motor mounts...
I have a 1990 Civic Si with the stock d16a6. I already searched, but it is still not clear to me where these inserts go. There are 4 poly pieces in the kit they sent me. I believe 2 of the pieces go to the mount at the front underneath the engine and the other 2 pieces go the the mount at the rear underneath the engine. Can someone please clarify that this is correct and if there is any trick to installing these?
Thanks in advance.
Old Jul 19, 2005 | 10:37 AM
vegaskurt's Avatar
Default Re: Energy Suspension motor mounts... (luderchris)
Its for the passenger side mount and drivers side mount. You use two inserts on each mount.
Old Jul 19, 2005 | 10:41 AM
luderchris's Avatar
New User
Default Re: Energy Suspension motor mounts... (vegaskurt)
Well, I guess I was way off base.
Are the mounts from the engine to the body or from the engine to the Tranny?
Are they up top or below the car?
Thanks for the help.
Old Jul 19, 2005 | 10:48 AM
luderchris's Avatar
New User
I thought th Prothane kit was for the passenger and driver side and the ES kit was for the front and back mounts.
Old Jul 19, 2005 | 10:51 AM
APEX CRX's Avatar
I think you were right the first time. the inserts are meant for the rear mount (on the rear x-member) and the front mount (front x-member) these are the torque mounts. Since the engine is transverse the load goes front to back not side to side when you accelerate. If I remember correctly just unbolt the front one off and install the insert then re-install the mount.
THE REAR IS A BITCH to do. you'll need to loosen the mount but not take it off and slide each insert in place.
my advice is patience on the rear and use some lube if it didn't come with it.
Old Jul 19, 2005 | 10:52 AM
luderchris's Avatar
New User
Default Re: Energy Suspension motor mounts... (APEX CRX)
ok that's what I thought.
Thanks.
Old Jul 19, 2005 | 03:21 PM
luderchris's Avatar
New User
I got the front one done.
Now -- is it better to attack the rear mount from the top or bottom???
Anything need to be removed to get to it???
Old Jul 20, 2005 | 07:06 AM
APEX CRX's Avatar
I did the rear from the top. not much room from ther bottom. I don't remember having to remove anything. just take your time and don't curse too much
Paul 631
Jan 5, 2013 07:18 AM
saemoonyang
11
Nov 3, 2011 12:33 PM
ls_bitik
Aug 1, 2007 12:14 PM
.BigSexy
Suspension & Brakes
Jul 18, 2006 01:45 PM
JICsube
Dec 11, 2002 05:07 AM
