eg/ek camber kit
this kid on HT is selling an "ingalls." amber kit for the Front AND Rear for an EG, i have an Ek with gsr front brakes.... will the camber kit fit ??
Modified by BLUE EH3 at 6:04 PM 7/20/2005
As long as I dont have to take out any more Metal Gears
No they wont. Even if u are using the integra brakes, u are still using the EK upper A-arm, and the EG camber kit wont fit. However the rears will fit no problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">are u sure the rear "ingalls." camber kit will fit my ek hb </TD></TR></TABLE>
mid-west si is right, no matter what brakes you have, its still the upper control arm that is going to be swapped, and you only have to worry about the front camber, my rear tires are just fine with no tire wear even with 6 months of use, of course unless you SLAM your car, but getting like omni, skunk front a arms and adjusting them and getting an alignment sucks big *****, its hard to align
i dont have any wear on my fronts! only my rears!.. i heard ek get camber wear in the rear!... my boy has an EG dropped 2in and never had a camber issue!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">i dont have any wear on my fronts! only my rears!.. i heard ek get camber wear in the rear!... my boy has an EG dropped 2in and never had a camber issue!</TD></TR></TABLE>
I'm 100% sure that the rear camber kit is interchangable between EG and EK civic, in other words, yes it will fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">The front Ingalls kit shares part #'s for the front kit for integras, del sols, civics, legends, and more IIRC</TD></TR></TABLE>???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">I'll verify when i get home since I have one that Ingalls says works on like 15 different cars....</TD></TR></TABLE>
The front Ingalls camber kit that I have is part# 35730. Look at all of the applications that it works with......
http://www.ingallseng.com/parts/35720.html
