Wheel Rub part two
Old Jul 18, 2005 | 10:34 PM
Axis-civic's Avatar
Default Wheel Rub part two
So thanks to the people who gave some help with my wheel problem. I just have a few more questions. OK so i have a 93 eg6 hatch, with 17" axis wheels. 205/40 rubber, and it is lowered 1.7-ish inches. I am getting VERY bad rubbing on the lips of the rear wheel wells, and some rubbing on the front. I Was considering going to coil overs instead of springs but I think that i will get the same problem again if my car is either too low, or is there is too much wieght in it. Can i get the wheels machined so they snug in tighter?--although they're already fairly tight up with the control arms. What exactly IS offset? I think the place that installed them said it is a 45 offset. Should i get the fenders flared? or rolled? raise the car? I cannot take back OR exchange the wheels which really sucks. Has anyone else with an eg6 had this same problem?
Can't drive my car more than 20 km/h. Holding up traffic.
Oh yeah, also i was considering removing the weather stripping in thr wheels wells BUT i dont think it will make enough diferenece plus i'm afriad to damage the tires, but more importantly my brand new paint job....
Thanks guys.
Old Jul 18, 2005 | 11:54 PM
Morning Call's Avatar
a pro should be able to roll the fenders fine without messing your paint...
removing the weather stripping would allow more tire movement but only once the fenders are flared
and i believe the offset is how far out the tires are from the hub?
Old Jul 19, 2005 | 11:33 AM
B-twentyVTEC's Avatar
any pics?
Old Jul 19, 2005 | 08:50 PM
i kHaNhz's Avatar
You can take out the rubber piece off the fender and grind that small part down to be smooth if thats the case. That is what I did with my car and it rides perfect and no paint was scratched, just be careful. Make sure you have good name tires also.
thomasw91
Nov 6, 2009 08:40 AM
HamiltonRex
Oct 12, 2005 11:56 AM
markuz
Apr 16, 2003 09:31 AM
mr_mbuna
Jan 14, 2003 08:28 PM
sk898
Dec 18, 2002 02:22 PM
