Supercharged B16A del sol bogging at 1/2 throttle
Old Jul 18, 2005 | 10:18 PM
delslowly93's Avatar
Default Supercharged B16A del sol bogging at 1/2 throttle
1St Post.
Just finished installing jackson racing supercharger on B16A del sol. When half to full throttle is applied the engine begins to sputter a few times and then backfires. The car does seem to idle really well(but that seems to be the only good thing)The sc has a 8psi pulley and a FMU is being used for the fuel. The car also has stock injectors and stock fuel pump if that helps.
Things that I have checked and replaced:
-Timing(7 degrees BTDC), new spark plugs(correct gap), spark plug wires, fuel filter, air filter, cap and rotor.
I would really appreciate your help.
Thanks, Mike
Old Jul 18, 2005 | 11:09 PM
sicky's Avatar
grammer nawzi
Default Re: Supercharged B16A del sol bogging at 1/2 throttle (delslowly93)
Try putting this in the forced induction section of the site. Might be more beneficial for you.
Old Jul 18, 2005 | 11:34 PM
''s Avatar
there's your problem... FMU...
Old Jul 18, 2005 | 11:41 PM
RedEj8's Avatar
Default Re: (L337HXR)
Jackson racing superchager kits come with a new hi flow fuel pump and bigger injectors. That might be ur problem.
digital sol
Aug 30, 2018 07:56 AM
bman2700
Aug 10, 2014 11:09 AM
kwolf15
14
Sep 22, 2011 05:23 PM
cyb593
May 29, 2007 07:32 PM
a12rnulfo
Nov 21, 2006 09:53 PM
