car is acting weird...thinking fuel pump
Old Jul 18, 2005 | 09:06 PM
rtpassini's Avatar
Default car is acting weird...thinking fuel pump
(h23 in a sol)
i was driving, and all of a sudden it just started decelerating like i let off the gas. so i pull over pop the hood. fuel pressure is at like 15 psi. okay great. try listening to see if the fuel pump was priming. i dont think it was. but its sometimes hard to hear. i got it started. drove a while. then later i was hauling ***. took 1st to about 5800 then suddenly the car takes a nose dive like i quickly let off the gas but still in gear and this weird noise happened (sounded almost grinding like) but it still drove no problem (possibly just drop in fuel pressure? i think i know what the noise might have been though) get back to where i was. parked it.
i go out later to see if i can figure something out. started it up. revved it up to see if something would happen. to about 6k. it bogged out after that. couldnt hear the fuel pump. again. only like 15 psi. tried starting a few more times and eventually got it and drove home.....
what do you guys think.
sorry for all that.
Old Jul 19, 2005 | 07:45 AM
rtpassini's Avatar
any ideas?
Old Jul 19, 2005 | 10:28 PM
utahbmx's Avatar
Default Re: (rtpassini)
Yes if you are bogging and and your fuel pressure is low it is very likely that your pump craped out on you.
Old Jul 21, 2005 | 02:57 PM
dIveR$E[323]'s Avatar
Default Re: (utahbmx)
it could be a lot of things... when was the last time you changed the fuel filter? do you have a aftermarket FPR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by utahbmx &raquo;</TD></TR><TR><TD CLASS="quote">Yes if you are bogging and and your fuel pressure is low it is very likely that your pump craped out on you.</TD></TR></TABLE>
very possible... fuel pressure is hella low.
Old Jul 21, 2005 | 04:31 PM
rtpassini's Avatar
i think the solder on the negative side of my kill switch poll broke off and it was a loose connection. which is why this was happening...i think.
monkeynuts
May 26, 2009 01:19 PM
lmananT
Jun 4, 2008 10:56 PM
boostng r
Jun 30, 2005 09:09 AM
B18C1 Civic EG
11
Jan 15, 2005 12:41 PM
Integgedout
Jul 10, 2004 11:36 PM
