QUICK!!! REAR BREAK PAD INSTALL calipers wont compress
Old Jul 18, 2005 | 08:27 PM
Benjithx's Avatar
Default QUICK!!! REAR BREAK PAD INSTALL calipers wont compress
Help, I can't get the rear break pads to compress. I opened the lines and diconnected the parking brake line but nothing. what am i dong wrong??? Please help i need to drive this to work tomorrow
Old Jul 18, 2005 | 08:30 PM
BlueIntegraBoy's Avatar
Default Re: QUICK!!! REAR BREAK PAD INSTALL calipers wont compress (Benjithx)
You have to turn the piston while pushing it in. Either that or your caliper froze up.
Old Jul 18, 2005 | 08:33 PM
Stoich EG2's Avatar
Default Re: QUICK!!! REAR BREAK PAD INSTALL calipers wont compress (BlueIntegraBoy)
If you mean DECOMPRESS, turn your car on. it will relieve the pressure because it works off a vacuum (brake booster)
edit: if you're talking about the PISTON inside the CALIPER, either use a C clamp or a big flat headed screw driver and turn it in.
Old Jul 18, 2005 | 08:34 PM
vw eater's Avatar
is it a 90 si by chance..?
Old Jul 18, 2005 | 08:37 PM
Benjithx's Avatar
Default Re: (vw eater)
sorry, it is a 2000si and it won't decompress. I tried a huge c-clamp. it just laughed at us
Old Jul 18, 2005 | 08:41 PM
T4eg's Avatar
Default Re: (Benjithx)
U have to twist the piston in
Old Jul 18, 2005 | 08:42 PM
SOHC4life 96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">sorry, it is a 2000si and it won't decompress. I tried a huge c-clamp. it just laughed at us</TD></TR></TABLE>
They make a special tool to do it. You put it on a 3/8" extension bar and turn and push it in. You could TRY it with a screw driver but it doesnt work quite as good. The tool costs like $10 and you can get it at autozone.
Old Jul 18, 2005 | 09:47 PM
Benjithx's Avatar
Default Re: (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">You have to turn the piston while pushing it in. Either that or your caliper froze up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ADVAN EG2 &raquo;</TD></TR><TR><TD CLASS="quote">
big flat headed screw driver and turn it in.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">U have to twist the piston in </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
They make a special tool to do it. You put it on a 3/8" extension bar and turn and push it in. You could TRY it with a screw driver but it doesnt work quite as good. The tool costs like $10 and you can get it at autozone.</TD></TR></TABLE>
My Girlfriend will be at all your houses soon to give out some free handy's thanks guys
Old Jul 19, 2005 | 08:59 PM
i kHaNhz's Avatar
Just get a needle nose and twist it in, easy as 1-2-3!
Old Jul 19, 2005 | 09:03 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (ikhanhz)
I just use a pry bar to turn em.
Old Jul 19, 2005 | 09:07 PM
aemciv's Avatar
you put the screw driver in sideways. I mean you dont use the end of the screw driver you place the shaft of the screwdriver in the slot. Haha.
and I believe it is counter clockwise.
prose
Old Jul 20, 2005 | 12:50 AM
EG_intheworks's Avatar
Default Re: (aemciv)
for the tool at autozone/kragen. Has different sizes for different pistons, only a couple bucks.
Old Jul 20, 2005 | 09:14 AM
hatchi's Avatar
Default Re: (EG_intheworks)
its not a push in caliper like the front brakes. the rear calipers are twist type like a screw. that's why you see the + shape in the center
Old Jul 20, 2005 | 09:28 AM
Civichatch2k's Avatar
Just rotate the piston it will go down...I ust needle nose pliers and got it to work.
Old Jul 22, 2005 | 06:47 AM
93CivicSI's Avatar
This is the part you need to turn your rear piston in: http://shop.store.yahoo.com/br....html
BUT - as others have said, you can get it cheaper at autoZone or Pep Boys or Checker Auto - etc....
Morasso
Mar 20, 2008 05:12 PM
RGoose18
Jan 27, 2006 11:38 AM
Louie_EM1
Mar 14, 2004 09:40 PM
onyx00
Jan 11, 2002 03:38 PM
wickedxbo1
Dec 30, 2001 07:51 PM
