looking for a hook up on some parts
Old Feb 17, 2002 | 05:27 PM
Looose_R's Avatar
Default looking for a hook up on soem parts
motul brake fliud, itr brake master cly and booster, itr proportiate valve, and some gunmetal jdm H center caps and jsut rear stailess steel lines
also, anyone ever try the carbo pads without resurfacing the rotors?
Old Feb 17, 2002 | 05:32 PM
Xian's Avatar
Default Re: looking for a hook up on soem parts (b20bastard)
you don't have to resurface the rotors to swap to Carbotech pads... it might be a good idea to go at them with some 60 grit sandpaper to break up the old brake pad transfer layer though...
edit: btw, I have all the stuff you're looking for but currently I'm using it all on my ITR
[Modified by Xian, 9:33 PM 2/17/2002]
Old Feb 17, 2002 | 05:45 PM
Looose_R's Avatar
Default Re: looking for a hook up on soem parts (Xian)
thanks itll all be on my psuedo R by the end of the week you got teh center caps too? find them less tahn 200? if so where
Old Feb 18, 2002 | 05:46 AM
cobalt's Avatar
New User
You should resurface a rotor if there is any grooving on the rotor surface, or else it will take longer for the new pad (any new pad) to fully mate to the rotor. The car will still stop, but not as well as it would if you started with a new rotor or turned your existing rotor.
-Andie
usdmftw
Mar 26, 2012 04:02 PM
Willard
Jan 13, 2006 08:41 PM
acuraLSSE95
Jul 28, 2003 06:39 AM
totaled
Jan 22, 2003 06:04 PM
EG6-SiR
10
Sep 10, 2001 07:19 AM
