HOme Made DOHC ZCturbo Fuel Management set up
Old Jul 18, 2005 | 07:55 PM
cmyrex's Avatar
Default HOme Made DOHC ZCturbo Fuel Management set up
What type of fuel management would be good to run? What size INjectors to Run without using a stand alone fuel management system? What to look for in using Dsm injectors and what i need to run them on a honda Fuel rail? Will an LS computrer and Ls injectors work on this setup?
Modified by cmyrex at 12:12 AM 7/19/2005
Modified by cmyrex at 12:14 AM 7/19/2005
Old Jul 18, 2005 | 08:09 PM
atomikpunx2's Avatar
http://www.homemadeturbo.com
they have write ups on the injectors...
http://www.turboedit.org
http://www.pgmfi.org
hacking and reporgraming obd0 nonvtec ecu's (ie pr4 / pm6) crx / civic si ecu, anything with a d16a6 stock.
(LS is the same as stock 240cc crx / civic injectors)
Old Jul 31, 2005 | 10:17 PM
cmyrex's Avatar
Default Re: HOme Made DOHC ZCturbo Fuel Management set up (cmyrex)
thanks for the info
Old Jul 31, 2005 | 10:39 PM
boosted_hatch_216's Avatar
have your ecu chipped and run turbo edit, your gonna need someone in your area to tune the car for youor your gonna have to buy a wideband and have it tuned, the dsm's will go into your stock rail with a little bit of boring in believe, and i wouldnt se a stock map and injectors for this.
mitchell88
Mar 16, 2013 12:56 PM
feriotypeR
Engine Management and Tuning
10
Dec 16, 2009 09:31 AM
hondacrx2
Apr 13, 2007 04:27 PM
swiftstyles
Jan 14, 2004 12:21 PM
