D15B 14b
no matter wat ur ecu will throw a map sensor code. when the map sensor reads the boost, ur check engine light will go on and ur car will prolly wont go when u step on the gas.
1. u can either chip ur ecu so it can trick the map sensor
2. check valves . use at least 4.
silverbulletgsr
May 20, 2004 08:24 AM
