shift linkage
Old Jul 18, 2005 | 07:03 PM
baked_beanz's Avatar
Default shift linkage
alright i have a 90 si hatch with ls swap. what shift linkages will work with it. will a 88 integra one work?
Old Jul 18, 2005 | 07:05 PM
Bunger's Avatar
Default Re: shift linkage (baked_beanz)
Swap linkage... contact JDMShit, I know they sell them seperate from the mounts.
Losrocket_'s Avatar
You need a B series linkage that is either cut and welded to fit or you can buy a HASport one. An '88 Integra wont work.
Old Jul 18, 2005 | 07:14 PM
like i have one on there but. i cracked my tranny and pulled it out. but i cant get the little pin out from the tranny to the shift linkage
Old Jul 18, 2005 | 07:16 PM
Bunger's Avatar
Default Re: (baked_beanz)
Just get an 8mm punch and knock the pin out... or drill it, don't spend the $100 for new linkage.
my friend had a 88 integra with a 9093 ls swap. and he cut a welded it to work that why i was saying 88 integra one but anyways will that work
Old Jul 18, 2005 | 07:24 PM
88EFhatch's Avatar
Like it was stated above just take an 8mm punch and some pb blaster and soak the sum bitch, then bang the sucker as hard as u can it will come out trust me. Dont spend the extra $100-150 for a new linkage
Old Jul 18, 2005 | 07:29 PM
Losrocket_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baked_beanz &raquo;</TD></TR><TR><TD CLASS="quote">my friend had a 88 integra with a 9093 ls swap. and he cut a welded it to work that why i was saying 88 integra one but anyways will that work</TD></TR></TABLE>
That one wont work. That linkage is modified to fit the '88 Integra. Even though he has a B series in it the linkage wont work. Just like a '84-87 Civic w/ a B series linkage wont fit an '88-91 Civic w/ a B series. Try the methods that others are saying to get the pin out. If that doesnt work and you really just want a new linkage i'd get a HASport linkage. Theres a sponsor on here that sells them for i think $140 shipped but thats an expensive fix.
Old Jul 19, 2005 | 06:11 AM
ok ill try guys thanks for the advice
Old Jul 19, 2005 | 07:17 AM
99teggsr's Avatar
They dont call it the "bitch pin" for no reason. But if you soak it up with WD or PB and wait like 10 mins and then try punching it.
mine took me about 45 mins to get it out.
efhatch1991
Jun 29, 2013 10:41 AM
88 EF Hatch
Mar 9, 2009 01:36 PM
efjones9
Aug 12, 2008 01:53 PM
Paulie Pesos
Sep 15, 2007 01:24 AM
TYPErCRX
Mar 6, 2005 02:46 PM
