tranny help!!!!!!!!
whats up people? i need help. i went a lil while ago to start my EK and i pushed the clutch pedal in and started it. i let go of the pedal and it stayed in the same spot. i tryed puttin it in 1st gear but it wont go in. non of the gears will go in. i think its the clutch. can anyone tell me whats up? how much would it cost for a new clutch? i was planning to put in a b16a should i jus spend the money on finishn the swap? let me kno thanks.
First and foremost, find out what the problem is. Don't jump to conclusions.
What is the condition of your shifter linkage bushings?
What is the condition of your shifter linkage?
Do you hear any grinding when driving?
How does your clutch pedal feel?
Have you done any transmission work recently?
1> the bushings were changed when i put in my B&M short shifter a few months age.
2> the shift linkage is fine
3> no recent tranny work
4> pedal is stuck to the bottom of the floor.
Bingo @ #4.
Might be your clutch master cylinder. Check for any leaks inside the cabin, in front of the clutch pedal where it goes through the firewall.
Bleed the hydraulic system and check if it helps.
i jus tryed it again and it came back out. i turned on my car and drove it around the block and it jus came back out. could that be signs of the clutch going out?
Ideal
Oct 20, 2005 06:35 PM
