Water got into ballast i think, hid's goes on and off
ok we had a flash flood, water was above my hood lol it was nuts....anyway water got into my ballast or wiring or something on my drivers side hid and it stopped working and i was like fuckkkk.....but then i tried to turn it on hours later and it came on but only for like 20 seconds......and now it comes on from 5-30 seconds every time i turn it on.....like it comes on again and again when i keep turning them on and off......do i just need to let them dry or what happened?, thanks guys
bulb and ballast work.....but i need to get a tester to see which wires have power coming from the car.....tried combinations but hid still not comin on
most fucked up **** with the hid's man.......we put the tester on em and gave them a positive charge and the left side works....but then we connect the wires from the car to the hid wires they dont.....and theres no power in the fuse on that side
so basically there is no power going to the headlight on the left side.....my friend said check if there any breaks in the wire from the ecu to the fuse?
ok tested headlight again.....its REALLY week and doesnt have enough power to light the hid's.....i put a regular halogen bulb on that side and it didnt work....i put on my brights and the light came on very slow and dim.....its not getting enough power....anyone can please help me
ok....tested one more time........put a new halogen bulb on both sides......high and low beam works on passenger side.......drivers side still only the high beam works....but its not dim now.......just the damn low beam on the drivers side is not working.....and its not the fuse....help!!!!
well the low beam wire is still getting no power...and i tried every troubleshooting technique...i think i have to run a new wire......but i hooked up the hid's to the high beam wires which were both working
on my first set of HID's (McCulloch kit), i ran a relay straight from the battery and used none of the factory wiring.
my current set, off of a Lexus GS300, i just wired it to the factory plugs, and havent looked back.
but yeah, you could get away with using the high beam as the power source. as for your exact problem, i really dont know, as you've already looked for all the other possible causes.
neo1z
Mar 9, 2003 12:05 PM
