itr wont start
Old Jul 18, 2005 | 05:09 PM
b16std's Avatar
Default itr wont start
ok here goes well i figured i would give it a shot posting in here maybe you guys experienced the symptoms i am having... its a 97 jdm itr motor/trans from h.m.o in a 89 civic std model...all wired obd1 car has plnety of power just wont crank over no more like the starter isnt gettin juice the meter i used said its getting 12v+ which i think should fire it over i tried 3 dif starters and nothing and idea? had stock itr flywheel and exedy clutch..car runs great when i pop start it ..
Old Jul 19, 2005 | 02:39 AM
MrMike's Avatar
Default Re: itr wont start (b16std)
check to see if the starters getting power from the ignition switch. u can start it manualy by jumping the positive to the starter solenoid where the ignition signal plugs into.
Old Jul 19, 2005 | 08:00 AM
IHateJDM's Avatar
Default Re: itr wont start (MrMike)
check the grounds again (especially the starter ground).
Old Jul 19, 2005 | 10:18 AM
HondAcura's Avatar
Just a suggestion, for the first start, you may want to jump start the car then just leave it running for a while. -either way some things you want to look into replacing: SPARK PLUGS
SPARK PLUG WIRES
DISTRIBUTOR CAP & ROTOR
PCV VALVE
CHECK VALVE ALIGNMENT
Old Jul 19, 2005 | 05:44 PM
b16std's Avatar
Default Re: itr wont start (HondAcura)
all done already 2 weeks old parts...
Old Jul 21, 2005 | 05:25 AM
b16std's Avatar
made some progresss yesteday tryin to get it started, i replaced the starter but it appartly wasnt the right one, but i made a ground for the starter and grounded it out and it shot out and spun..but when it was in the trans it went like it spun once like its hitting something but the starters look dif ..but its progress knowing that it may be narrowed down to a ground prob
teetstyshon
Feb 12, 2013 10:27 PM
egbarteezy
Apr 5, 2011 05:01 PM
spooncivic01
Feb 16, 2008 07:22 PM
erniecars
Feb 13, 2006 03:14 PM
b16std
14
Jul 21, 2005 05:24 AM
