Help! Pressed out top motor mount bushing
Old Jul 18, 2005 | 03:59 PM
arren123's Avatar
Default Help! Pressed out top motor mount bushing
I pressed out the top driver side motor mount bushing so I can put in the ES inserts.
It looks like there is a metal sleeve still in there. It that something that I'm supposed to press out or cut out with a dremel?
Modified by arren123 at 8:15 PM 7/18/2005
Old Jul 18, 2005 | 04:15 PM
arren123's Avatar
Default Re: Help! Pressed out top motor mount bushing (arren123)
Nevermind. I just read the instructions again and it said to press out the orginal rubber section and the outer steel sleeve.. It does seem to want to press out though and I don't have a steel disk big enough or hard enough to press it out.
Old Jul 18, 2005 | 04:18 PM
Black R's Avatar
25 Year Member
.....you need to take a hacksaw or sawsall to that metal ring and cut it out.
and fyi, Energy Suspension doesn't make any of the upper mount inserts.
Prothane, however (which is undoubtedly what you have) does - I suggest you use the RACE disc that is included.
And don't forget that myself and Dr. Pooface have posted much on this topic previously some years ago in the archives.....
Old Jul 18, 2005 | 04:23 PM
arren123's Avatar
Default Re: Help! Pressed out top motor mount bushing (Black R)
Thanks.. I was searching for the posts about the upper mount.
I just tried using my hacksaw, but the blade doesn't seem to be doing crap.. I might have to take a trip to the hardware store.
Old Jul 18, 2005 | 04:30 PM
Finland's Avatar
I just used a chisel and beat it out.
Old Jul 18, 2005 | 04:45 PM
Black R's Avatar
25 Year Member
.....you're lucky you're old sk00L arren:
https://honda-tech.com/zerothread?id=680862
.....get ready for the vibrating chair rydE.
Old Jul 18, 2005 | 04:48 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
But won't the car try to shake itself apart with the RACE insert, that's hard like a hockey puck? Or am I wrong here, I have the STREET insert put into mine but have not got it up and running yet so I have no first hand experience. Oh, I have ES and Prothane inserts for all 5 mounts btw.
Old Jul 18, 2005 | 05:00 PM
Black R's Avatar
25 Year Member
Default Re: Help! Pressed out top motor mount bushing (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">But won't the car try to shake itself apart with the RACE insert, that's hard like a hockey puck? Or am I wrong here, I have the STREET insert put into mine but have not got it up and running yet so I have no first hand experience. Oh, I have ES and Prothane inserts for all 5 mounts btw.</TD></TR></TABLE>
I have prothane RACE inserts for the uppers and rear, and ES for the lowers.
I have had them since I posted that thread.
No regrets. Street disc = weak sauce.
Old Jul 18, 2005 | 05:13 PM
Pondus's Avatar
Prothane rear and upper for me too, guess I could always give it a try with the RACE insert, at least it would be popular with the ladies
.....get ready for the vibrating chair rydE.</TD></TR></TABLE>
Old Jul 18, 2005 | 06:15 PM
arren123's Avatar
Thanks BlackR.
I finally got that damn sleeve off.. Had to use the hacksaw to cut a line up to the mount.. And then I took a screwdriver and pounded away with a hammer to tear the sleeve at the score line. It came off quite easily afterwards..
So.. I finally got it in my car, but haven't done a test ride yet.
One question.. This could've been a stupid thing on my part, but...
Was I supposed to remove the steel sleeve that lines up the inserts when you are assembling it?
I took it out before I put the mount back in the car and realized that I couldn't torque the bolt to spec anymore since there's nothing there.
The steel sleeve was only for assembly, right? I forgot to check if the bolt will fit through it.
Old Jul 18, 2005 | 06:26 PM
arren123's Avatar
DAmn.. I'm dumb. . I just pull it out again and found out that the sleeve was supposed to be be in. doh!
Old Jul 21, 2005 | 11:40 AM
Black R's Avatar
25 Year Member
.....we've all been there.
85_305
Honda Civic (2001 - 2005)
19
Jul 28, 2009 02:14 PM
bunske123
Oct 10, 2007 10:50 PM
VTEC-Brazil
Feb 22, 2005 05:20 AM
Thundersquid
Oct 23, 2003 10:43 PM
