emergency brake indicator(on dash)
Old Jul 18, 2005 | 03:43 PM
civic duty's Avatar
Default emergency brake indicator(on dash)
I noticed today that when I make a right turn, my emergency brake indicator light flickers and then goes off when i straighten out. This only happens when turning right. Any suggestions or thoughts would be beneficial. 99 coupe, drum brakes.
Old Jul 18, 2005 | 03:57 PM
BlueIntegraBoy's Avatar
Default Re: emergency brake indicator(on dash) (civic duty)
Check your brake fluid level in your reservoir.
Old Jul 18, 2005 | 04:16 PM
civic duty's Avatar
Default Re: emergency brake indicator(on dash) (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Check your brake fluid level in your reservoir.</TD></TR></TABLE>
I just went and checked it and everything seems to be in order there, I put a little more in and took it for a drive around the block and the light came on. I appreciate the response though.
Any other suggestions?
Old Jul 18, 2005 | 05:42 PM
civic duty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic duty &raquo;</TD></TR><TR><TD CLASS="quote">Any other suggestions?</TD></TR></TABLE>
Old Jul 18, 2005 | 05:51 PM
Crx Jimmy's Avatar
Default Re: emergency brake indicator(on dash) (CsiRUN)
ummm civics dont have a rear axle -unless they are 4x4
Old Jul 18, 2005 | 05:56 PM
jr_istheman's Avatar
Patrick, we can bleed the brakes at my house if you'd like.
Edit: This is litterbox.
Old Jul 18, 2005 | 05:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CsiRUN &raquo;</TD></TR><TR><TD CLASS="quote">you got to much play in your rear axle</TD></TR></TABLE>
Old Jul 18, 2005 | 06:17 PM
civic duty's Avatar
Default Re: emergency brake indicator(on dash) (jr_istheman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr_istheman &raquo;</TD></TR><TR><TD CLASS="quote">Patrick, we can bleed the brakes at my house if you'd like.
Edit: This is litterbox.</TD></TR></TABLE>
Thanks George, I'll give you a call
If anyone else has any more ideas or thoughts, feel free to shoot it our way.
Old Jul 18, 2005 | 07:30 PM
Crank's Avatar
is the ground for the e-brake disconnected? this happend to me before too. check it out
Old Jul 18, 2005 | 07:44 PM
moto1320's Avatar
Default Re: emergency brake indicator(on dash) (Crank)
If you have a buddy with the same one, try switching reservoir caps. They go out and that is often the problem.
B16smku
Jan 25, 2008 03:21 AM
Dav94Lx
Aug 30, 2007 11:58 PM
lowRIDAH
11
Jul 22, 2005 01:37 AM
philosofy1
Apr 25, 2005 11:39 AM
cjbarry
Acura TL, RL & ZDX
Jun 25, 2004 01:05 PM
