alternator cable, wire
Old Jul 18, 2005 | 03:34 PM
egctreg's Avatar
Default starter cable, wire
i changed the starter wire that runs from my starter to the positive of the battery when connect both neg. and pos. it sparks what could the problem be?
Modified by egctreg at 4:10 PM 7/19/2005
Old Jul 19, 2005 | 05:30 PM
PrettyLude's Avatar
you sure the wire you just changed is not grounding itself out somewhere?
Old Jul 19, 2005 | 11:57 PM
Jimmy's Avatar
Global Moderator
Care to explain a little better?
Maybe some more detail, eeh?
Old Jul 20, 2005 | 12:53 PM
hatchi's Avatar
Default Re: starter cable, wire (egctreg)
usually it will spark for a second when you touch positive wire
Old Jul 20, 2005 | 01:46 PM
egctreg's Avatar
i took the starter off and found out that it was the bolt that goes to pos. was not staying up and it was grounding it self
Old Jul 20, 2005 | 03:39 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egctreg &raquo;</TD></TR><TR><TD CLASS="quote">i took the starter off and found out that it was the bolt that goes to pos. was not staying up and it was grounding it self</TD></TR></TABLE>
Jdm John
11
Nov 25, 2009 03:53 PM
loosestring
Jul 23, 2009 05:25 PM
spens 91 Ef
May 8, 2009 05:53 AM
G60
Dec 29, 2006 10:24 AM
CLE
Mar 16, 2006 03:38 PM
