power steering removal
I just finished taking out all the a/c componets and since i planned on removing the power steering one day i decided to do it now since it's like 90% out.Im just not sur what to do with the main line.The one that goes behind the motor and then to the rack.Can i just remove this line and let the fluid drain out or is ther somthing special i have to do to it.
Thanks for the help 92 GSR
you can remove the line and clean up the mess, but then AT LEAST loop the two lines on the rack to keep it sealed. Better to use a loop and a reservoir to keep the rack lubed.
Actually you can just let all the fluid run out and then find a bolt to put back in the place of the p.s. line to keep out dust and debris. I was unsure of the same "fluid" issue a year ago when I built my GS-R and after talking to ALOT of people I found there was no problem letting all the fluid out and in fact it made steering a little easier (all though not much) and I have not had a problem since I did it last Jan '04 and I have done plenty of road and drag racing with on top of 30k miles driven. So just drain it, plug it and go!
well i already got the pump unbolted but the lines are still connected.it looks like thers a little more work than i thought so can i just bolt the pump back on and leave the belt off until i get the proper hardwear tommorow.and still drive with no problem.
well i do one thing to my car and make a problem for my self.I must have hit the radiator with the power steering pump or somthing cause when i got back from my test drive i noticed smoke from under the hood.Is pissing a little line of rad fluid onto my exhaust mani.So now i have to do a rad job.
Anyway thanks for your help
'06-V6-MT
Jun 30, 2015 05:47 PM
