low profile-Jack
Does anyone know about a low profile jack for cars that is mad low to the ground...? I need to know the price for one. This guy I kinda know is selling his for $100 bonez. Its new it was used three times no scratches its aluminum with one spring and a cyclinder and it can hold up to 2tons. Is it worth it, does it seem real need help........PLEASE!
At the shop I work at we use an airbag one for lowered cars its half an inch thick hook up the air and it goes up 2 feet, I wouldent trust it for **** tho under it, but for lifting the car its good.
if it's the craftsman then the price is about right, if it's no name then the price is high.
check harbor freight tools. (harborfreight.com) a 3ton is $85 +S&H. so figure ~100.
the craftsman version is 120
(they have dropped in price since they came out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree »</TD></TR><TR><TD CLASS="quote">Drive onto a couple of 2x4's, what I do. Then, you can use any jack in the world.</TD></TR></TABLE>
No doubt...done this many times.
i had a pepboys jack and a craftsman jack. i like the pepboys a lot better. the handle is bigger and it was easier to jack up. it was bigger and lighter too.
the craftsman is just for the name and looks.
As long as I dont have to take out any more Metal Gears
Just for everyones FYI, those low pro jacks usually have a bigger piston, so in 4 pumps, the cars tires should be off the ground. Standard jacks would probably take 8-10 pumps to get it to the same height. I think this accounts for the low pro jack's price as well
blue one from harbor freight is nice, i work for sears and i kinda "borrowed" one of the craftsman ones for lowered civic that was slammed on the ground and it worked GREAT. got myself in a lot of trouble for "borrowing" a 150dollar jack but who cares anyway?
Are the low profile ones good for people with body kits (me! me!)
Its a bitch jacking up a car with sideskirts because the bar of the jack hits the side skirt before the platform hits the bottom of the car.
buy the low profile pro jack from Costco... It's like 80 bucks, pumps up quick with two big pistons, and starts out really low to the ground.My civic has been lowered over 4 inches with coilovers and I still had plenty of room to scoot under it.
Plus buying it at costco (as long as you keep your reciept) means you can always take it back if there's a problem - always.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 »</TD></TR><TR><TD CLASS="quote">AC Hydraulic Jack
http://www.asedeals.com/hydraulicjacks2.html
nice jack!!!
</TD></TR></TABLE>nice jack!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">I just lift my fender with my hands and slide the jack under with my foot
i've done that so many times
and after i lift it i put my spare
(steelie 14") under and lift up the other side
</TD></TR></TABLE>i've done that so many times
and after i lift it i put my spare (steelie 14") under and lift up the other side
That's what I used to do at the track w/ my friend's car. Only I didn't lift the fender, it was the frame by the window.
</TD></TR></TABLE>That's what I used to do at the track w/ my friend's car. Only I didn't lift the fender, it was the frame by the window.
