is ELD in fuse box on '92 DA GS-Rs?????
Old Jul 18, 2005 | 01:41 PM
VtecSyndrome's Avatar
Default is ELD in fuse box on '92 DA GS-Rs?????
I have been throwing a code 20 and code 1 after I get on it or when excess load is applied on my Integra, problem is the ELD does not seem to be in the fuse box and I can't find info anywhere so far on the wiring for my car. I know what the ELD looks like by itself in the fuse box but again I can't see one, any help would be awesome if anyone knows what's up???
Old Jul 18, 2005 | 01:49 PM
92integraVTECgsr's Avatar
Default Re: is ELD in fuse box on '92 DA GS-Rs????? (VtecSyndrome)
what else do u have done to your car/motor?
Old Jul 18, 2005 | 02:34 PM
Default Re: is ELD in fuse box on '92 DA GS-Rs????? (92integraVTECgsr)
Pretty much bolt on's (i.e header, intake, exhuast, U.R. crank pulley w/ no ac or p.s), it's a '93 SiR II motor and ECU but it has been running in the car strong for over a year. I know the car has an ELD and that is probably all that is wrong with it I just can't believe how many books I've seen that don't even remotely mention an ELD in the DA's, EG's should be the same I would think but my civic book did not help me much either.
Old Jul 19, 2005 | 04:54 PM
any takers on this issue yet?????
Old Jul 19, 2005 | 05:10 PM
carchitect's Avatar
DA chassis don't use an ELD and that is why you can't find one. I'm running a P72 ecu on my car with a hondata S200 and fortunately I can disable the ELD feature. I would like to run one someday especially when the next injector upgrade goes in. You might be able to take apart a EG or DC underhood fusebox and wire a ELD into it. My P72 ECU w/o hondata was not setting off a MIL but did have that code and didn't affect the performance whatsoever.
Joe.
Old Jul 20, 2005 | 04:11 PM
Default Re: (carchitect)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carchitect &raquo;</TD></TR><TR><TD CLASS="quote">DA chassis don't use an ELD and that is why you can't find one. I'm running a P72 ecu on my car with a hondata S200 and fortunately I can disable the ELD feature. I would like to run one someday especially when the next injector upgrade goes in. You might be able to take apart a EG or DC underhood fusebox and wire a ELD into it. My P72 ECU w/o hondata was not setting off a MIL but did have that code and didn't affect the performance whatsoever.
Joe.</TD></TR></TABLE>
I was thinking that it did not have an ELD but I have heard that all fuel injected hondas have one or least a form of one but I am not sure how accurate that is.
My performance does not seem to be affected and Vtec still comes on strong but I just don't like having that light on if I am not sure what else is being affected. I have an SiR II Ecu (can't remember what the code is) but why would it start throwing a code for a sensor I suppossedly don't have after working perfect for over a year and a 1/2?????
Bo0sted4Do0r
Apr 27, 2006 09:38 AM
Jamez
May 19, 2005 01:00 PM
h22zexhatch
Apr 25, 2005 07:29 AM
Oren
Feb 22, 2005 12:26 PM
