Inetgra Type R suspension
I saw a set of 4 with LCA for about 280. Are ITR suspension worth it? i also heard that the shocks are Tokico??? I've searched already and nothing really came up with info one this. so if you guys can help me answer this questons i'll appreciate it thanks.
Well, an ITR suspension is far more than springs, shocks and LCAs. There are sway bars, end links, all the bushings, etc. Also Tokicos were not ITR OEM. I say its probably not worth the installation effort and the cost. I would save my sheckles and buy Koni/Ground Control with the spring rates that I wanted. ITR springs will make a difference just not give you the full effect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hype Vtec »</TD></TR><TR><TD CLASS="quote">I saw a set of 4 with LCA for about 280. Are ITR suspension worth it? i also heard that the shocks are Tokico??? I've searched already and nothing really came up with info one this. so if you guys can help me answer this questons i'll appreciate it thanks.</TD></TR></TABLE>
Depends on what you're doing.
If you have an EG hybrid and you are driving it on the street, the ITR suspension might work out perfectly for you, although I'd check to see exactly which Tokico are included and how many miles on them.
If this is for a track car project, I'd look elsewhere.
JunIntegra
Suspension & Brakes
May 23, 2005 09:52 AM
