3rd to 2nd gear mis shift..
Old Jul 18, 2005 | 12:39 PM
'00DC2's Avatar
Default 3rd to 2nd gear mis shift..
I was driving my car sunday morning when somebody in an accord tried to race me. I dropped to 3rd from 5th and quickly hit the rev limit, so I dropped it down in what I thought was 4th dropped the clutch and all of a sudden revvvvvvvvv! **** almost 8k on the tach with a stock y8 motor. Fukk!! I missed 4th for 2nd. quicky engaged the clutch, car still ran. Finished the race, beat the accord and everything. Now Im paranoid that I may have messed up the valvetrain or something. Is there anything I should get checked out. I dont hear any noises or feel any difference in acceleration. Any help suggestions would be appreciated!
Old Jul 18, 2005 | 12:42 PM
Deemeetree's Avatar
Electrician
If you can't hear anything or feel anything different on the way it runs, you MIGHT be ok.
But, lesson learned. Stop being immature by racing on the street. Simple as that.
Old Jul 18, 2005 | 01:29 PM
Dueceification's Avatar
Default Re: 3rd to 2nd gear mis shift.. ('00Civic)
Your lucky. This kid I know went to go from 3rd to 4th at redline put it into 2nd gear and popped his 1 month old Type S Swap. Anothe friend did the same thing and thought he blew up his motor but luckly his pressure plate exploded and thats what was making the rasping noise. If your engine sounds noises escpecially from the head then you may have a problem. Though I dont think reving a y8 to 8k will completly **** the motor. You should be fine. If something was wrong you'd know. If anything you may have taken some of it's potential life away.
Old Jul 18, 2005 | 01:32 PM
deemack79's Avatar
From: The Burbs of NYC, where you can park your car on the street & they wont steal it NY
Default Re: 3rd to 2nd gear mis shift.. (93b16hatch)
i rev my y8 to 8200 all the time but it is balanced and all the good ****, still with the stock valve train.......45,xxx and still purrin' like a kitten
Old Jul 18, 2005 | 02:51 PM
Deemeetree's Avatar
Electrician
Default Re: 3rd to 2nd gear mis shift.. (deemack79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deemack79 &raquo;</TD></TR><TR><TD CLASS="quote">i rev my y8 to 8200 all the time but it is balanced and all the good ****, still with the stock valve train.......45,xxx and still purrin' like a kitten</TD></TR></TABLE>
Define "all the good ****". BTW, are you making power up at 8,200 RPM or are you just doing it "for show"?
Old Jul 18, 2005 | 03:40 PM
'00DC2's Avatar
Okay I feel a little bit better now, but I think I might get it checked out still..just in case.
Old Jul 18, 2005 | 03:45 PM
FalkenSiR's Avatar
Default Re: ('00Civic)
8k rpms most likely didn't damage anything. Just learn your lesson.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Stop being immature by racing on the street. Simple as that.</TD></TR></TABLE>
Old Jul 20, 2005 | 04:11 PM
deemack79's Avatar
Default Re: 3rd to 2nd gear mis shift.. (Deemeetree)
power drops off at around 74-7500 rpm, but when i shift at 8200 it falls right back at vtec(5500)......ex tranny....
Old Jul 20, 2005 | 04:13 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deemack79 &raquo;</TD></TR><TR><TD CLASS="quote">power drops off at around 74-7500 rpm, but when i shift at 8200 it falls right back at vtec(5500)......ex tranny....</TD></TR></TABLE>
You don't lose 2700rpm when you shift. Period.
Also, who the **** races jack with a stock Y8 Civic?
Old Jul 20, 2005 | 04:15 PM
Kyles ej1's Avatar
what do u have to make power up to 7500? and revving a y8 to 8200 with a stock valvetrain is really stupid if u ask me
Old Jul 20, 2005 | 04:24 PM
Ignitecivic's Avatar
Default Re: 3rd to 2nd gear mis shift.. (93ejay1)
as long as u didnt push on the gas while u drop it into 2nd, ur fine.
Old Jul 23, 2005 | 01:37 PM
deemack79's Avatar
Default Re: 3rd to 2nd gear mis shift.. (Archidictus)
reject......what i said was the power falls off at 74-7500 rpm, but when i shift at 8200 rpm it falls right back to vtec which is at 5500 rpm on a stock p2p ecu. if i was to shift at the regular redline, it falls to 4500 rpm which is 1k rpm below vtec and the car is noticeably slow due to the fact that it is still on the small lobe.
learn how to read before you run your mouth capt. stupid!!!
Outkast95LS
Apr 8, 2008 12:31 AM
snzh22
Dec 9, 2006 08:20 PM
midwesta
12
Jun 7, 2006 03:59 PM
accordisslow
Jan 25, 2006 01:24 PM
torqueless
Feb 11, 2005 03:34 PM
