Do you have to buy 5 pt. harness when using Sparco Torino's?
is the 5 pt. harness a must, or can you use the stock seatbelt?
i'd feel kinda gay buckling everything up and strapping down just to go buy some milk....
also, is the seat comfortable? i sat in one at the auto show and i'm hooked!!!! but questioning the comfort after cruising for an hour. any input would be appreciated.
thanx.
jason
p.s. any pics or torino's would be appreciated
thanx.
jason
I sat in one at a local shop, and the quality is pretty good (well, okay I guess, but way better than all of the cheap-o seats). They are huge, and very heavy. Also, as long as your seat base will allow you to bolt in the OEM belt clip, you don't need a harness. Actually, the torino won't accept a 5th or 6th point anyway, just the 4 point, unless you cut it.
they don't weight more then the stock seats do they?
350 POST!!!!!! BOOOOYAAAAAA!!!!!!
[Modified by out_a_bounz, 6:56 PM 2/17/2002]
Sparco lists them at 37 lbs!!! In contrast, my Corsas are only 16 lbs. I don't know how much the OEM seats weigh off hand.
Yes you can use the stock seatbelts on the Torino's.
There is a little cover on the side you take off and unscrew the bolt. Then put your stock seatbelt in its place.
And yes they are very comfortable. But no fat chicks will fit in you car
Recaro g/f filter
heheh.... i'm waiting for someone to post a pic of a scale with a recaro balanced on top like they do with wheels, someone has gotta come through
-rob
-rob
lol gf filter?!?!
now thats getting your money's worth!!
after doing a search, i found that the rear seats weigh about 30lbs......couldn't find anything regarding the fronts
now thats getting your money's worth!!after doing a search, i found that the rear seats weigh about 30lbs......couldn't find anything regarding the fronts
Chris F
14
Oct 16, 2004 07:50 AM
Power Rev Racing
18
Sep 5, 2004 08:58 AM
